smells like Urine but no little boys in the house.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lea, May 11, 2006.
  1. Lea
    Lea New Member
    Apr 12, 2005
    My sister has a 1960's home and all the bathrooms were recently remodeled before she moved in with all new fixtures and new tile. The strangest thing is that the down stairs bathroom which is only used by guest smells like urine. Not the typical sewer smell but pee. No little boys or dogs use this bathroom. One guest said the smell reminded him of mold. We can not figure where this smell is coming from. It is a pier and beam home with a crawl space underneath and there is another bathroom directly above this bathroom on the 2nd floor. Would a small leak behind the wall create this smell?
  2. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    Did you chxk the seal on the toylet?
    Sometimes the wax is bad.
    If the wax is sufficient, there should be no sewer gas. I like to feel the wax squishing down as I push the toilet down. Or it could be a crack in the toylet that allows gas to escape. Or it could be a mouse loose in the walls and ceiling peeing all over and smelling it up that way too. I've seen it man! I had to tear apart the walls, just ripped them down to get to that bad smell. Rip, rip rip! I painted over the urine with Zerolac, a white lacquer that covers over smells. They use it for fire restorations. I hated those mieces to pieces!
    the Mad Plumber
  4. Lea
    Lea New Member
    Apr 12, 2005
    Wow, thank you Mad Plumber. I discussed your suggestion of a possible mouse problem with my sister and you guessed it! She has just recently discovered a mouse problem in her upstairs attic. They must be hanging out in the walls of this bathroom. Thanks so much for your suggestion. Now she needs to catch the little suckers and block their access into the house.
    This forum is great. It helped me select and install a new toilet, move plumbing lines. Now, it has educated me on how to identify the smell of mouse pee! Thanks so much!
Similar Threads: smells Urine
Plumbing Forum, Professional & DIY Advice Abandoned Bathroom Smells Moldy Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Multiple types of sewer smells? Jun 28, 2016
Plumbing Forum, Professional & DIY Advice New bathroom smells like sewer, apparently from the tub Apr 18, 2016
Plumbing Forum, Professional & DIY Advice Unvented sink smells a little?? Feb 3, 2016
Plumbing Forum, Professional & DIY Advice Laundry Room smells bad Mar 6, 2015
