Smell coming from kitchen sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wire2fiber2, Aug 25, 2005.
  1. wire2fiber2
    wire2fiber2 New Member
    Aug 25, 2005
    HI:
    Having returmned from vacation, we found a foul smell coming fro the kitchen sink :( . Smells like rotting plants. I have tried draino foaming liquid, draino crystals but the smell is still there. I was wondering what could be the cause and how to resolve it.
  2. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Depending on how long you were gone... the trap may have dried out, letting sewer gases come out of the drain...
    Is it draining properly? If it is, and it were me - I'd pour a good slug of bleach into the drain and let it sit for an hour or so before washing the concoction down thoroughly.
    Also, is the garbage disposal on that drain too? You might have some crap stuck in the teeth.... I throw a couple of handfuls of ice into the unit once in a while and crush it with the disposal followed by a good flush of hot water - it seems to clean things up pretty well.
    If it's not draining properly, you've obviously got something stuck.
    Either way, you should be able to disconnect the p-trap under the sink and clean it out thoroughly with a flexible bottle brush or similar tool.....
  4. wire2fiber2
    Aug 25, 2005
    Forgive my ignorance but what is a p-trap
  5. thezster
    thezster New Member
    Jul 18, 2005
    That would be the "loop" - U shaped - under your sink. It should be held together on both ends by compression fittings, which are easily unscrewed (by hand pressure alone)... disassembled, cleaned, and put back together...
    It holds a small amount of water constantly to keep sewer gasses from coming up through your drain. It can dry out if left unused for an expended period of time.... It also catches heavy sediment and traps it there...
  6. wire2fiber2
    Aug 25, 2005
    Thnx for the info, I wil try to clean this out as suggested.
  7. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    I stongly dislike using all those chemicals to try and unclog your drains or to "freshen" them up. They're highly corrosive and do no favours to your system. I probably get a little more excited about them, because where I live, we seem to think it's alright for the city to dump our waste straight into the ocean with only one stage of treatment (basically having a catch/pit for collecting the biggest and heaviest of solids). Go with thezter's recommendations and pull that puppy apart on your own - the P trap that is. I bet what you'll find is that it's quite clean and required a good flushing. And nothing... almost nothing... can compare to rancid bits of food stuck in your garburator for a couple of weeks. If you have one, I bet that's your culprit. Feel free to toss a lemon 1/4 piece at a time along with that ice treatment...
    sorry about the soapbox moment guys :)
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    smell
    I agree with kristi............lemon
  9. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    we don,t know if 2 wire is on a septic system
    bleach wouldn,t be his best friend?
  10. thezster
    thezster New Member
    Jul 18, 2005
    "Treehuggers".... :D
    Actually, you guys are right on..... and I don't know why I didn't think of it.... water with a slice of lime is our drink of choice in our house.... and lots of limes get sent down the disposal..... and it never smells....
  11. wire2fiber2
    Aug 25, 2005
    No, I'm on the city water/waste system. I don't have a garbage disposal but I feel that it probably is food stuck in the p-trap as mentioned in an earlier post.
    I will try to clean out the p-trap or replace if necessary and see if this recitifies the problem.
  12. thezster
    thezster New Member
    Jul 18, 2005
    With all the ecologically "sound" advice.... going around..... let us know how it turns out....
  13. hwebb78
    hwebb78 New Member
    May 10, 2010
    Ocoee, FL
    Time to crack open an old post LOL
    I'm having the same issue here, the plant smell...doesn't smell like sewage, smells like a head of lettuce is stuck in my kitchen sink drain. I have double sinks, and the smell is coming from the left sink, I don't have a disposal either. I ran bleach down the drain, and still nothing...did anyone find a solution to this?
  14. jimbo
    jimbo Plumber
    San Diego, CA
Similar Threads: Smell coming
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Odd occasional smell coming from vents Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Sewer Smell coming from pipes connected to hot water heater Nov 19, 2016
Plumbing Forum, Professional & DIY Advice Water coming under base of toilet, sewer gas smell laundry room? Feb 6, 2016
Plumbing Forum, Professional & DIY Advice Stagnant Urine smell coming from toilet water Mar 23, 2015
