Smallest Shower & Toilet possible?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hevnbnd, Aug 30, 2009.
  1. hevnbnd
    hevnbnd New Member
    Mar 25, 2009
    Texas
    I am building a shop and need just a toilet and shower in a bathroom. The sink is going to be outside the bathroom. What configuration would you go with to use the least square footage? Thanks and any drawings would be great.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    The plumbing code will dictate the size of your shower. The following is from the Illinois plumbing code. It would be best if you checked with your local codes for shower compartment sizes.
    Dimensions. Single family shower compartments or stalls shall have at least 1,024 square inches outside dimension (O.D.) floor area and shall be at least 32 inches in shortest outside dimension. All other shower compartments or stalls shall have no less than 1,296 square inches outside dimension floor area and shall be at least 32 inches in shortest outside dimension.
  4. hevnbnd
    hevnbnd New Member
    Mar 25, 2009
    Texas
    Sorry should have been a little more specific. It is in the country so there is NO inspections.
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    It does not matter if you are in the country or a big city. There ARE PLUMBING CODES THAT MUST BE FOLLOWED!!
    Every State, county, township and city has a plumbing code they follow. If your area does not have its own code then they would follow the county code, if the county does not have one then it will follow what ever code the state follows. There are not if ands or buts about it.
  6. hevnbnd
    hevnbnd New Member
    Mar 25, 2009
    Texas
    Thanks for your help. lol Not if you do your own work. There are NO INSPECTIONS!
  7. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Then why not just put a floor drain in a room big enough for just a water closet on one, with the shower valve right on the opposite wall with the shower head coming from the ceiling, kind of like a camper bathroom?
  8. hevnbnd
    hevnbnd New Member
    Mar 25, 2009
    Texas
    I was thinking about a swanstone floor pan and then using backerboard and tiling up the wall and then a toilet facing it. However his would need 32" wide by about 6.7' long space for the toilet and shower. Is that the best utilization of space?
    Swanstone R-3232-010 VERITEK SINGLE THRESHOLD SHOWER FLOOR - 32" X 32"
  9. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You won't find much help here to do any plumbing that does not follow code. Codes are not in place to create hardships or extra work for homeowners or plumbers, but are to insure the health of your family and community is not put at risk and that it functions properly. If you someday desire to sell your home, there will be an inspection prior to the buyer received a loan. Anything that does not meet code will have to be brought up to code before the loan is approved. There can also be fines.
  10. jimbo
    jimbo Plumber
    You may live where permits are lax, but EVERY state and county in the US has a plumbing and building code.
    Showers have been described. Toilets must be centered in an area at least 30" from wall to wall, and there must be 24" free floor space in front of the toilet. This boils down to needing 2½' X 5' for the toilet. Add the 32" for the shower, and roughly a 5' X 5' space could be made to work.
    Anything smaller than these measurements is very uncomfortable to use, which is why there are codes. If you chose to build otherwise, then the folks who have to use it are the ones who suffer.
  11. hj
    shower
    In this case the plumbing codes are to provide a USABLE shower and toilet. You can make them smaller, but you will live with the cramped space "forever". Why do people insist that "codes" and "inspections" are there just to make life miserable for them?
  12. Terry
    Aug 17, 2004
    Frankly, if you want advice on plumbing for the Third World, with no inspections, you are in the wrong place.
    What state are you plumbing for?
    So we can give the correct advice for plumbing that meets USA codes.
    Without that, the thread will be pulled.
Similar Threads: Smallest Shower
Plumbing Forum, Professional & DIY Advice Is pipe/water pressue pressure limited to the smallest denominater ? May 11, 2013
Plumbing Forum, Professional & DIY Advice what is the smallest diameter pipe that cab be used for a vent? Sep 1, 2007
Plumbing Forum, Professional & DIY Advice looking for smallest water softener... Apr 5, 2007
Plumbing Forum, Professional & DIY Advice What is smallest pvc bend? Jul 24, 2005
Plumbing Forum, Professional & DIY Advice Shower cartridge Today at 8:34 AM
