small pump in stream - pressure switch? Tank?
Discussion in 'Irrigation / Sprinkler Forum' started by JimLS, Jul 29, 2011.
  1. JimLS
    JimLS New Member
    Jun 26, 2010
    Illinois
    I would like to pump from a very small stream for use to water trees and bushes. I plan to install a pump relay to control when the pump is running but also want to make it so the pump can be started in the house and then go to one of several faucets (large yard) to turn on the faucet. I am thinking a pressure switch would shut off the pump when the faucets are closed but allow someone to go to a faucet and get water. Do I need a tank? Would a flow switch be a better choice? A pressure switch set near the cutoff pressure of the pump without a tank seems like it should work for all but very low flows. Want to make this reasonably easy to operate by others. Since the stream is small and sometimes stops toward the end of summer I also planned to monitor motor current and shut off when prime is lost. Could use a float switch but there is extra wiring and complications - distance between pickup, pump and end use and stream has high flows at times that could take out the float switch.
Similar Threads: small pump
Irrigation / Sprinkler Forum Big booster pump, small well pump Feb 7, 2016
Irrigation / Sprinkler Forum Suggestions for small lawn strip irrigation Jun 23, 2009
Irrigation / Sprinkler Forum New Sprinklers small problem Apr 13, 2009
Irrigation / Sprinkler Forum Digging pipe under small concrete slab/brick walkway Jan 21, 2009
Irrigation / Sprinkler Forum new system: leaking a small amount Dec 13, 2008
