small leak above zone valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tommyo, Oct 11, 2009.
  1. tommyo
    tommyo New Member
    Oct 11, 2009
    RI
    I have a small leak above one zone valve, (2 are on system) I am assuming this has to drained before any attempt to solder(suggestions) will this do anything to the zone valve ?, and should I use map gas or propane seeng as when doing this. When drained and refilling is ther anything else I should be cautious about, and how would I bleed air after completion, thanks for any advice.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Yes, water needs to be drained
    Yes too much heat will damage the valve
Similar Threads: small leak
Plumbing Forum, Professional & DIY Advice Small leak under slab Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Small leak Mar 22, 2015
Plumbing Forum, Professional & DIY Advice repairing leak on older/smaller copper pipe advice wanted Apr 22, 2014
Plumbing Forum, Professional & DIY Advice leak with tub drain -- larger pipe going into smaller Feb 9, 2014
