small dripping leak above zone valve?
Discussion in 'Boiler Forum' started by tommyo, Oct 11, 2009.
  1. tommyo
    tommyo New Member
    Oct 11, 2009
    I have a small leak above one zone valve, (2 are on system) I am assuming this has to drained before any attempt to solder(suggestions) will this do anything to the zone valve ?, and should I use map gas or propane seeng as when doing this. When drained and refilling is ther anything else I should be cautious about, and how would I bleed air after completion, thanks for any advice.
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Where is the leak coming from? If it's coming from the soldered connection on the ZV then there may be more to it then just a bad solder joint (unless you KNOW this is what it is).
    It could be that the copper has worn thin and now had a pin hole leak in it etc.
    You need to sweat copper out of the zone valve and inspect it.
    Drain all water from the system. When you refill you need to bleed the air off through the bleeder valves located on the rads (some will have one some won't).
    If you're not that comfortable with these systems etc I would strongly recommend you hire a professional.
Similar Threads: small dripping
Boiler Forum Mitigating effects of oversized of Alpine 105 Mod Con boiler in small house Oct 8, 2014
Boiler Forum Efficient Boiler for Small Heat Load and Multiple Zone Types Nov 27, 2011
Boiler Forum Is my boiler too small? Nov 25, 2010
Boiler Forum Who makes a boiler thats small enough for a 1000 sq ft house?? Aug 6, 2010
Boiler Forum A boiler for the small new vacation house Dec 31, 2009
