Small Drip Irrigation System from hose bib
Discussion in 'Irrigation / Sprinkler Forum' started by dmc in nc, Jun 28, 2008.
  1. dmc in nc
    dmc in nc New Member
    Sep 6, 2005
    We just moved into a townhome with a very small yard. We would like to install a drip irrigation system from our hose bib that's on a simple timer. The more we looked, the more we became concerned with backflow prevention and 'continuous use' of the hose bib. Here are the concerns:
    We have several hanging plants that we wanted to hook into the system. They are several (7 or so) feet above the hose bib (we also have a small hill in the yard that we'd like to irrigate, and topographically it is above the hose bib, also). It appears that the standard backflow prevention devices need the water source to be 6" above the highest sprinkler/drip emitter. Other backflow prevention devices look very big and very expensive. Is there a backflow prevention device that would work without breaking the bank (it's such a small system!)?
    The 2nd concern is with our hose bib. It's a Woodford Model 17 Freezeless Wall Faucet (www.woodfordmfg.com/Woodford/Wall_Faucet_Pages/model-17.htm). On the website, the spec says that it is not rated for over 12 hours of continuous use. Does this mean we could not leave it continuously 'on' and have a timer (or other valve) downstream? If not, is there a way that we could have a timer downstream of this faucet while leaving it 'on' continuously?
    I appreciate any help you can offer!
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Your bibb has a vacuum breaker device built in, but as stated this type of device is not designed to have continuous pressure without flow.
  4. dmc in nc
    Sep 6, 2005
    Just for clarification ...
    The built-in vacuum breaker device makes it safe to use a standard backflow preventer for a drip system on the hose bib (even with emitters above the hose bib)?
    And ...
    There's no way to have a time downstream of the hose bib b/c of the continuous pressure without flow?
    Thanks for the clarification.
    Any ideas about what you'd do in this situation to get a small drip system on a timer?
    Thanks!!!
Similar Threads: Small Drip
Irrigation / Sprinkler Forum Big booster pump, small well pump Feb 7, 2016
Irrigation / Sprinkler Forum small pump in stream - pressure switch? Tank? Jul 29, 2011
Irrigation / Sprinkler Forum Suggestions for small lawn strip irrigation Jun 23, 2009
Irrigation / Sprinkler Forum New Sprinklers small problem Apr 13, 2009
Irrigation / Sprinkler Forum Digging pipe under small concrete slab/brick walkway Jan 21, 2009
