slurp/suck noise after turning off faucets
Discussion in 'Shower & Bathtub Forum & Blog' started by brittsi, Nov 22, 2005.
  1. brittsi
    brittsi New Member
    Nov 22, 2005
    Canada
    Whenever we have a shower/bath - it seems like for a good 20 minutes afterwards, these (gurgle) noises continue from the pipes in the bathroom. Only from the shower/bath - never from the sink.
    We just bought this house a little less than a month ago. The noise isn't loud, just annoying enough to wonder if something might be waiting to burst!
    I recall at the previous house we lived in, a similar noise occurred, and once the faucet was changed, the noise was gone.
    Any advice would be great!
    Thanks...
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    noise
    Maybe a drain/vent condition.......
    over..
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Sounds like a sluggish drain situation to me, although it could be the vent partially clogged, too.
    Try cleaning the drain pipe out with a good enzyme-based drain cleaner like DrainCare (available at big boxes, hardware stores, etc.). It won't harm the tub/shower finish or the pipes, and it will eat out all of the organic hair and gunk overnight. (Do NOT use a caustic-type drain cleaner, such as Drano, for just a sluggish drain.) If it still gurgles, you may need to do the DrainCare treatment more than once.
    You just run warm water down the drain, pour DrainCare down it according to the directions and let it eat overnight. Then flush it out with VERY hot water the next morning. I start with a kettle full of boiling water, and then run the hot water from the tub spout to flush it all down.)
    Good Luck!
    Mike
  5. brittsi
    brittsi New Member
    Nov 22, 2005
    Canada
    thank you...
    I will try as you suggested with the enzyme-based drain cleaner ... and the very hot water. The tub seems to drain at a normal rate, so this would be an issue further down the drain pipe then, I suppose -right? Ok, thanks! I appreciate the both of you responding to my dilema -
    I will let you know the results! Thanks a million!
    brittsi
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    slurp
    Magic.
    Know the TV commerical where the lady calls the plumber and he cleans the drain? And he tries to sneak out of the house with a bottle behind his back?
    People are suckers for something easy. May not work, but if everybody tries it just once, then thats what an add will do.
    There is only one way to clean a drain and that is to use the right equiptment for the particular job.
    Get it over with and do it the right way.
    No Brooklyn bridges...
  7. xerodoc
    xerodoc New Member
    Nov 26, 2005
    Noises
    Just a thought, might be similar to the noises I get after a shower. The water from the shower head pipes is draining back through the tub faucet very slowly. I keep my shower /tub diverter valve mid position to release any water that has built up in the pipes. If I dont do this I get all sorts of sucking noises. Hope this helps!
Similar Threads: slurp/suck noise
Shower & Bathtub Forum & Blog Noise in shower Feb 1, 2015
Shower & Bathtub Forum & Blog What is this unsticking noise? Dec 8, 2014
Shower & Bathtub Forum & Blog Shower pressure dropped and noise increased Jun 7, 2014
Shower & Bathtub Forum & Blog Noise in wall behind bathtub... Jan 12, 2014
Shower & Bathtub Forum & Blog HELP....Shower valves/Pressure relief valves make noise - no one has an answer...yet Dec 19, 2013
