Sluggish drain on new sink rough-in
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Scott_, Feb 2, 2014.
  1. Scott_
    Scott_ New Member
    Feb 2, 2014
    illinois
    I have just completed a rough-in for a double vanity. I hooked up a single vanity to one side to test it and it drains, but it's a little sluggish. If I let the water run for a couple of minutes the sink fills up and it'll take a minute or two to empty. The drain and vent pipes are both 1 1/2". Here's a picture of the set up (the other side of the set up has a plug in it
    Can anyone help me figure out what's wrong and why it drains slow?
    Thanks,
    Scott
  2. hj
    I cannot tell why it drains slow from your photo. In fact it should drain extra fast because you have created two "S" traps which always drain faster because they do not have vents. More likely you have "vessel sinks" without overflows and they almost ALWAYS drain the way you describe.
  4. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    I would guess because you used the wrong fittings. A and B should be Sanitary-tees not Combos.
  5. Terry
    Aug 17, 2004
    Switch out A and B with santee's to prevent siphoning.
    And if you have a vessel sink without the overflow, you will need a special drain for it. Grid drains don't work and typical pop-ups don't work on those.
    HJ mentioned that above too.
  6. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Here a photo that Terry had posted.
  7. Scott_
    Scott_ New Member
    Feb 2, 2014
    illinois
    HJ, Hammerlane, Terry... Thank you for your quick response and excellent guidance. I used Terry's diagram (with santee's) when I did the original rough-in but I had someone who I thought knew plumbing review it before cementing everything together and he told me that the santee's should be replaced with the combos so I changed them out. Hammerlane, your diagram was really helpful explaining why the combos won't work. I also wanted to mention that the vanity I was using to test the setup has a vessel sink. The double vanity that will be used for the final install doesn't have vessel sinks, so not worried about needing a special drain, but just wanted to say I was impressed you guys knew the sink that was in place on the vanity for the test was a vessel. You guys are the best... Thank you again.
Similar Threads: Sluggish drain
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Yesterday at 1:36 PM
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Tuesday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
