Slower Setting Cement for PVC
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Oct 14, 2011.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Anybody make a slower setting cement for PVC.
    The last time I worked with setting my schedule 40, the cement *tacked* up pretty quick.
    I'm tapping into one area in which it's a tight fit and I may need to play with the angles a bit...
    Took a quick browse on Oateys site and did not see any cement that was listed as slower setting.
    Does such a cement exist
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I have been in that kind of situation, and that can be tough. If you have enough room and a bit of flex somewhere to be confident about being able to force the fitting into place, just chamfer all the edges of the pipe/s well and then use *plenty* of cement to help lube the fitting into place.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    A heavy body grey pipe cement made for large fittings, 2" to 12" will give you time. I use it ONLY, for all pipe. Coast hardware sells it online cheap in quarts. triple work the primer in .
    the clear low voc crap from home stores is bad stuff.
  5. chefwong
    chefwong Member
    Jun 14, 2006
    Aren't you in CA where everything has to be lead free and low VOC ;-)
    I have been stashing certain goodies that I fear will get phased out due to these voc laws....
    paint ain't what is used to be .....
    Oatey told me the same thing today however, they said the heavier cement will afford me a ~couple~ seconds more as in less than 10 seconds more. I suppose solvent is solvent. Once it evaporates - fuggadaboutit
Similar Threads: Slower Setting
Plumbing Forum, Professional & DIY Advice slower water flow, stuck pump Aug 27, 2015
Plumbing Forum, Professional & DIY Advice cold water pressure in faucet slower than hot water! Sep 16, 2009
Plumbing Forum, Professional & DIY Advice Setting drain fit tile shower Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Setting Basement Shower Pan Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Setting toilet on vinyl floor Jul 26, 2016
