Slow well replenish rate...to build or not to build?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by rinibean, Sep 7, 2012.
  1. rinibean
    rinibean New Member
    Sep 7, 2012
    Virginia
    We've resolved this so I prefer to delete the info, thank you for your help!
  2. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    with a 37' deep well with water at 21'... thats a big hole to have 350 gallons in reserve. someone else can do the math, but i'd think it would have to be something like 20+ inches in diameter.
    what are other people using in the area? is there no possibility of a deeper well with more water?
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    You need to talk to a driller, not a builder. Let them tell you what to expect.
    My guess is the builder skimped out and got the cheapest guy he could find, and then when he couldn't get the first well to work he made a 2nd bad hole.
    You should be shooting for 5-10 gallons per minute minimum. Anything less than that and it's going to have to be managed with more equipment.
    I believe Porky resides in VA, maybe he has some additional insight.
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Here in Ct there are state minimums for well yield, for example, a 6" well that yields 1 gpm must have a storage capacity of 400 gallons or 375' of storage which ever is greater. Unless the well meets state minimums, the town will not issue a certificate of occupancy. I would bet that Virginia has similar regulations.
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Like Texas Wellman said, these are shallow wells dependent on local rainfall! They were bored close to each other because it was convenient! I doubt that there have even been well permits for these bored holes. However you will find that out when you obtain an occupancy permit. Today most bored wells are frowned upon in many states because they are unreliable and unsafe. Even though they cost more I would prefer a deep well drilled by a licensed driller!
  7. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    I am familiar with the neighborhood you're talking about, and I think I've heard this story. You are bulding in a tricky area......for the rest of the forum...this neighborhood is in a tricky area at the interface between the Virginia Coastal plain (mud rotarty screened wells), and the Piedmont for open hole rock wells. Deep well water may or may not be available. I have a method that I've used in similar areas with great results, to obatin water from the shallow well zone. I'm not sure what the reluctance is, but I have made this offer to 3 major home builders in the neighborhood, and I make it to you. I will drill and test a well anywhere in the neighborhood, and GUARANTEE it to produce 5 gallons per miinute for a 24 hour test. If it doesn't produce, I will abandon the well and leave at no cost. The current wells in the neighborhood are 30 concrete cased, no bottom...not gravel packed, and probably not grouted much. I am offering a screened, gravel packed, grouted well that I've hod great success with in nearby areas. As far as long term concerns, this aquifer is subject to seasonal fluctutations in water level as it directly recharged by rainfall. I do a lot of work with VA DEQ and the greatest fluctuation they have reported in drought conditions is a 10-12' change in water level, so if we can install an efficient well that can tolerate 10-12' in drawdown, you will be alright.
  8. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    Meant to type 30" concrete cased wells.....they are contructed with 3' tall sections of 30" ID concrete stacked inside a roughly 48" borehole. As for minumums....Virginia just passed new laws for minumum welll yield and storage. A well producing more than 3 gallons per minute needs no additional storage. Wells less than 3 gpm need 150 gallons/bedroom storage per bedroom. I drill mud rotarty wells in the coastal plain. Properly installed screened, gravel packed wells in the Virginia coastal plain generally produce >50 gpm with 20' of 4" screen. The normal residential installation is a 10 gpm pump, and that generally has less than 5' of drawdown, so storage in the well is completely unnecesary.
  9. rinibean
    rinibean New Member
    Sep 7, 2012
    Virginia
  10. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    Let some others weigh in....the fact is, with a well and water system you either need storage, or sustainabe yield.....I personally would rather have a 10 gpm well with no storage, than a 1 gpm well or 2gpm well with even a million gallons of storage. Simpy put, no matter how much storage you have, if the well is only capable of a small yield, you will run out if you consume more than it produces....like a leaking toilet, or sprinkler left on, you will run out. I know they tried drilling deep rock wells in the neighborhood, with poor resuls. I am not sure if they drilled mud rotary deep wells....I am not sure it they would produce, but would have to do a test hole and a geophysical log myself to offer an opinion on that.
  11. rinibean
    rinibean New Member
    Sep 7, 2012
    Virginia
    So with 5 bedrooms, we're required to have 750 gallons of storage then. Does the standing water in the well count as storage, or is a basement tank required? Or, since we have two wells that will be combined to give us around 3.1, does the law requiring storage not apply?
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Arguing about the minimum and whether it is county, state, or some other AHJ, is moot. Assuming that you can buy/build and your financing is not contingent on well production, if you end up with a poor producer, you would not get a good price when trying to sell.
    When I built in '98, I had to certify my well could produce 5 GPM before I could get a building permit and financing. I grew up on wells that did not produce enough and we had to ration, so having and endless supply now is a pleasure. I have a 6" drilled mud well that goes down to bedrock as do many of my neighbours. One neighbour to my North ran out of water with his mud well and had a 300 foot rock well drilled at $48 per foot. Some folk around here had to go down more than 600 feet.
  13. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    Regarding the 150 gallons/bedroom/day storage.....it can be any combination of storage inside or outside the well.
    LLigetfa --- So do you have a screened well, or is it just cased to rock and then open hole?
  14. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Cased to within a foot of the rock with no screen, just the bottom of the open casing with crushed stone dumped in to hold back the mud. The formation is clay to within 5 feet of the bedrock, then fine sand/gravel glacial till. It took a lot of work to develop it to where it is now.
  15. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    Strange construction.....not sure why they wouldn't screen the sand/gravel????
  16. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I'm not a well driller so cannot answer that but will take a stab at it. I don't think they intended it to be a mud well. They originally welded on a drive shoe probably with the intent on setting it into the bedrock in anticipation of it being a rock well. I think they drove down the casing as they went, not knowing the formation until after they passed it. I'm guessing they didn't want to pull up all the casing to add screen to the last 5 feet of it and thought the glacial till would be stable enough to be the screen.
    They did not actually develop the well and only pumped it at 5 GPM to satisfy the minimum requirement. After I built the house I put in my 10 GPM pump, it sucked in the mud and I had to get the driller back to flush it out and set the gravel pack. It filled back in with mud again and I augered it out by hand and developed the well myself after the driller did a bunch of no-shows.
  17. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    That sounds reasonable to say, that they didn't plan on making that type of well from the beginning....they are probably normally rock well drillers, and didn't know how to react to that sand/gravel formation. It is normal to install and grout a casing and then install a well screen. Sounds like you've made it work. If you ever have problems, you can easliy install a reduced diameter screen in the 6" well with a packer assembly. If you were really concerned about sand/gravel intrusion, you could even install a prepacked screen (a screen in a screen with a proper gravel pack).
  18. ballvalve
    Dec 28, 2009
    northfork, california
    Lenders dont touch houses here without 3 gpm minimum.
    LLIg and VAwd: So you added gravel inside your open bottom casing?
    I have a 4" slotted liner in a 6" well but the bottom is open and it seems the clay-mud is working its way upwards. This too was thought to be a all hard rock well.
    would pouring some stiff cement down the liner be a viable way to seal off the bottom? Then use the now clogged pump to suck up the mud intrusion and re-use it or replace it....?
  19. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    You shouldn't pour it in....if you want to do that, you should pump in the exact measured amount through tremie pipe, so you know exactly where it goes. The easier solution for you to do yourself, would be to get a K Packer and plug the bottom. Look at western rubber figure K packer online.....get like a 4" x 2" threaded, and put a threaded plug in the bottom...then push it to the bottom of the well. If you have a pitless adapter, you may have to remove it to install the packer, and then put it back.
Similar Threads: Slow replenish
Pumps and Tanks Well Forum & Blog Slow Down Pentek Intellidrive Apr 22, 2016
Pumps and Tanks Well Forum & Blog Jet pump slow to build pressure Aug 31, 2015
Pumps and Tanks Well Forum & Blog Well slowly loses pressure, no water being used. Sep 7, 2014
Pumps and Tanks Well Forum & Blog pump is slow to come up to pressure May 24, 2014
Pumps and Tanks Well Forum & Blog New system slowly losing pressure Sep 21, 2013
