Slow utility/laundry sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chigundo, Jul 25, 2010.
  1. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    My laundry sink drain is very slow. When a large wash is done, it fills up to only an inch away from the top. I'm cheating a flood every time a wash is done.
    I unscrewed the trap plug and all seemed fine. I've tried drain-0 at one point but that was useless. I tried plunging and all I can hear is water coming up and down in the vent pipe.
    Here's a picture of the p-trap setup under the sink.
    [​IMG]
    Here's a picture of the stack this goes in to. The bottom right is where the p-trap from the laundry sink ends up. The arrow shows the pipe I can hear water swooshing up and down when I try vigorously plunging.
    [​IMG]
    And here's what I'm trying to avoid.
    [​IMG]
    No other drain in the house causes any issues so that leaves me to think it's not the main vent on the roof causing this problem.. but who knows. Any advice would be really appreciated.
  2. Ian Gills
    Jul 24, 2007
    USA
    I had the same thing. You need to call a plumber and have that drain snaked.
  4. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    probably years of lint build up somewhere in that drain?
  5. jadnashua
    Galvanized pipe could be all corroded inside and the opening could be quite small. A snake might ream it out, but replacement may be called for.
    When it corrodes, it gets rough, and any lint would be caught, build up, and slow the drain way down.
  6. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    would snaking a corroded pipe be a bad idea then?
  7. jadnashua
    It might clean it out, if it is really bad, it might break through. So, it would either fix it, or you'd have to replace it...hard to tell which without being there.
  8. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    Would the snake get entered into that cleanout access point in the second picture?
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Possibly but then again maybe not...
    It depends on where the clog is...
    You can snake all day long at a convenient location, but if you can't reach the clog from there you are doing nothing except waste time....
  10. Terry
    Aug 17, 2004
    The wye coming out of the concrete is 2"
    If you were to remove the 1.5" pipe and increase to 2" until you install a 2" x 1.5" x 1.5" Santee, it would help, after the lower section had been throughly snaked and cleaned out.
    Or you can just give it a good snaking and see what happens.
  11. weaver
    weaver New Member
    Jan 4, 2009
    NE Ohio
    redwood, May I have permission to quote you? I'm a retired priest, but I do preach every so often.
    Bob
  12. Redwood
    Dec 15, 2007
    Service Plumber
    Absolutely! Hopefully it reaches the person that needs to hear it...
  13. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    Would it also be ideal to set up the washer so it drains directly into the pipe instead of the utility sink? Or for older homes does this not matter? I guess I'd like to have the laundry sink's basin filling up as a warning that it's clogged again.
  14. hj
    1. Then it would probably overflow the drain pipe, and
    2. The sink would still fill up.
    Do what any logical person would do the FIRST time it filled up, and call a plumber. You can speculate all you want to, and spend days doing it, about whether it would work, or what problems you could have, but in the end the only thing that counts is that the water drains.
  15. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    I'm calling a plumber to fix/snake the drain but I'm also asking if it's best at that time to have the washer set up so it drains into the pipe.
  16. Ian Gills
    Jul 24, 2007
    USA
    Careful with what that plumber tells you. The plumber that snaked my drains said I could have a 2 inch standpipe, leading to a 2 inch trap that fed into my 1.5 inch drain. I know that can't be right. 1.5 inch pipe must mean using a utility sink to discharge a washer.
  17. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    His pipe comming out of the floor is 2in.
Similar Threads: Slow utility/laundry
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Tuesday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Bubbling Toilet and Slow Tub Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Kitchen Sink slow drainage Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Water is running slow Sep 20, 2016
