Slow tub drain?
Discussion in 'Shower & Bathtub Forum & Blog' started by hans_idle, Feb 7, 2008.
  1. hans_idle
    hans_idle New Member
    Sep 16, 2007
    Sitting on my butt at a desk all day
    Princeton Junction, NJ
    I have a standard 5' tub/shower in on of my bathrooms. When taking a shower, there are no drainage issues with a 2.5gallon/minute shower head. When someone takes a bath, however, the water takes a while to drain, or so it seems.
    The water comes in through a 1/2" pipe at 5 gallons per minute. Going out through a 2" drain, how long should it take to drain? I'm trying to figure out if there is some way to improve the drainage. It takes about 5 minutes to drain a tub with 5" or 6" of water in it. Not sure if that is normal.
    When looking at the plumbing for the drain, the nearest vent is about 4' away from the tub.
    -Hans
  2. Ian Gills
    Jul 24, 2007
    USA
    Is the drain clear? I had a very similar situation a few weeks ago. I left some liquid plumber in overnight and it shifted it.
    It is as good as new now. I think it was hair or soap buildup.
    Once thing I did notice was that slow drains collect a lot more hair than well-functioning drains. So a blockage accumulates blockage.
    Fascinating.
    I knew there was a problem when I took a shower and the bottom of the bath would start to slowly fill up around my toes. If it is clearing the water from a shower instantly without any puddling, I would not worry too much.
    So are you standing in water or not?
  4. hans_idle
    Sep 16, 2007
    No, the water doesn't accumulate when taking a shower, but it's a low-flow shower head and I take short showers. Maybe I'll try some of the organic desolvers in the trap to see if that improves it.
    Now that I think about it, there was a lot of crud in the pipes when I removed them for my master bath remodel. Maybe that's what I'm dealing with.
    I'll give it a try.
    Thanks.
Similar Threads: Slow drain
Shower & Bathtub Forum & Blog Shower drain is slow Nov 1, 2014
Shower & Bathtub Forum & Blog The downside to slow draining showers Aug 20, 2014
Shower & Bathtub Forum & Blog Slow draining bathtub Dec 12, 2013
Shower & Bathtub Forum & Blog Standing Water, Slow Drain in new tub install Apr 14, 2012
Shower & Bathtub Forum & Blog New Tub Drains Slowly Sep 17, 2011
