Slow leak in bathroom
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kramer12345, Aug 29, 2006.
  1. kramer12345
    kramer12345 New Member
    Aug 29, 2006
    I came home last night and there was a wet area in my bathroom which is in the basement. I did not see or hear any leak tried all the sinks and toilets in the house. I attributed this to maybe the shower curtain was open and some excess water had been the cause. This morning I woke up and there was a slight sweat of water on the floor below the bathroom sink. I heard a slow drip maybe one every two minutes. Then as I was leaving the drip stop completley and ideas what this might be? Thanks again for all your help!!! Craig
  2. prashster
    prashster New Member
    Dec 7, 2005
    If you are seeing water under the sink it's either from a leaky drain or water supply (or did I misunderstand your descrip)?
    There are like 20 different fittings in the water supply and the drain, so you'll have to check each one. Dry both assemblies and the floor beneath thoroughly with a towel. Then turn on the water full power, and feel each joint with your finger for building moisture.
    Most of these fittings will be compression/threaded fittings, so you should be able to solve any leak with a little tef-tape and retightening.
    Am I missing something here?
  4. kramer12345
    Aug 29, 2006
    I guess my cocern was the dripping from the wall and that no fitting appeared to have any moisture in the sink but I will give your idea a try tonight. thanks for the advice!
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Did I miss something? What dripping from the wall? Is the sink enclosed or free-standing?
    First, dry everything off.
    If there are shutoffs under the sink, turn them off and see what happens. If there's a puddle there after turning off the shutoff valves, that's moderately bad news. Let's ignore that for now.
    If there's no puddle, pour a bucket of water in the sink (leaving the shutoffs shut off) and see if any puddles show up. If they do, there's a leak in the drain somewhere, and it should be easy to see and fix.
    If no puddles from the bucket-of-water test, turn on one of the shutoffs at a time and see if the puddle returns. If it does, it's a leak in the corresponding supply line (hot or cold). Should also be easy to see and fix.
Similar Threads: Slow leak
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Tried to fix slow shower leak, now have no water Sep 15, 2015
Plumbing Forum, Professional & DIY Advice slow leak on CI baseboard (water heating) air pressure testing Sep 23, 2014
Plumbing Forum, Professional & DIY Advice Slow leak discovered where toilet flange meets drain Jul 31, 2014
Plumbing Forum, Professional & DIY Advice Advise to find a slow leak in CPVC Jun 9, 2014
