slow leach lines
tlbwat
The last time we had our septic pumped, the man said our leach lines were clogged, causing them to drain slowly. Any advice on what I can flush down there to clear them and allow them to drain faster? :(
King3244
Kelowna, BC
How would the guy who pumps your tank know that your leach field was clogged? The most he can see is the discharge pipe to the field.
RioHyde
Cincinnati, Ohio
If in fact your leach field is clogged up its probably clogged full of mud. I dont know of any way this can be cleared short of replacing the leach lines. Not saying there might not be a trick or two out there, but if a leach field has failed I recommend replacing it.
Aceto
new york
I would check your distribution box. My septic tank lid failed this fall. The contractor had me pull the top of the distribution box and I was amazed at the soap residue and other crud that had collected there. This might give you an idea of how bad you really are.
King3244
Kelowna, BC
Definately look in the distribution box!
But I ask again.....HOW does the guy who pumped the tank know that your leach field is clogged??????
Does he have x-ray vision? :confused:
