Slow draining washer drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ladyt, May 6, 2008.
  1. ladyt
    ladyt New Member
    May 6, 2008
    The laundry drain backs up when the washing machine drains. Older cast iron pipes, with "u" style trap connected to vent pipe( drain pipe, trap, then vent pipe). I tried bladder style connected to garden hose to force clog, worked with garden hose water down drain, but still backs up when machine drains. Should I try badder down vent?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A couple of questions. Do you have a new washer? Has the drain worked OK in the past? What size is the standpipe? Newer washers empty water much faster than older models. Older standpipes and traps were commonly 1-1/2" diameter pipes. These are too small for the newer machines, so backups are common. New standpipes and traps should be 2" diameter. If the drain worked OK in the past and no changes to the machine have been made, your drain may be partly clogged. Forget about bladders, chemicals, and DIY hand snakes. You need a professional to properly auger the drain and totally clear the clog.
  4. ladyt
    ladyt New Member
    May 6, 2008
    slow washer drain
    This is a duplex that was empty for a couple of months, but has been in use now since October. No previous problems for the previous tenents; they had a new machine. They pipe looks to be 2" in diameter, and over 2ft in length, the trap is about 4" in length and connected directly to the vent.
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    I believe a plumber who can auger the drain clear to the street is in your future.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    At least it will be the only proven effective method...
    The plumber cleaning the drain that is!
  7. ladyt
    ladyt New Member
    May 6, 2008
    Thanx everyone for your advice! It looks as though I'll be calling a plumber! I guess I can't do everything myself, even though I try:)
  8. Gary Swart
    Sep 1, 2004
    Yakima WA
    "A man's got to know his limitations." Clint Eastwood as Dirty Harry.:D
  9. Sandpiper Plumbing
    Sandpiper Plumbing Plumber
    May 4, 2008
    Northern by birth, Southern by choice
    Am I to understand that you have a new tenant in the unit? I've seen washer stand pipes that have run clear before, suddenly back-up and overflow because of a change of (or too much of) laundry detergent and the line gets suds-locked. Often reducing the amount of detergent or changing brands will reduce the suds and the line will go back to draining normally.
    Try running a full load, no soap, no clothing, just maximum water in the maching, run the spin cycle and see how it reacts. If it drains, it was suds problem. If it still backs up, call a local rooter guy and have the line jetted. Snaking will clear a clog but only jetting will remove the scale on the inside of the pipe.
Similar Threads: Slow draining
Plumbing Forum, Professional & DIY Advice Bathroom sink started draining slowly Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Slow draining sink (a.k.a - Pulling my hair out in Omaha) Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Urinals - Slow draining Dec 9, 2014
Plumbing Forum, Professional & DIY Advice new kitchen pipe slow draining Apr 18, 2014
Plumbing Forum, Professional & DIY Advice Slow draining tub a vent issue? Dec 20, 2012
