Slow drain
Discussion in 'Water Softener Forum, Questions and Answers' started by alexh, Jun 28, 2013.
  1. alexh
    alexh New Member
    Jun 18, 2009
    CA
    Hi,
    I just installed a 64k 5600SXT. I live in a slab house and the most convenient drain is an AC condensation drain pipe just outside the house. It's 1.5" and it simply protrudes about 6" above the cement next to the house. A 3/4" PVC pipe exits the house and terminates just inside the 1.5" pipe. I cut back the 3/4" pipe to test the drain etc. The drain goes to the sewer.
    The problem is that the drain rate on this pipe is less than 2 gal per min. Of course a high drain rate is not needed for AC condensation but it stills seems awfully slow. That pipe is not really exposed to a lot of debris but it has not seen much if any use in 15 years so it may need cleaning. Is it surprising that a 1.5" pipe would have a drain rate this slow or is this expected for a AC condensation drain?
    My only other drain is the washing machine drain which is inside the house. I would have to run the drain pipe into the house and the piping would be visible along one short wall of the washroom.
    My 5600 valve says 2.5ga/min drain on it but I think it's actually higher because I upgraded the tank from 40k to 64k and they sent me a new drain restrictor.
    Thanks
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    It is not recommended to run the drain in the condensation line because of possible damage if it backs up. I would suggest you run it to the washer drain in 5/8 tubing.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Before re-routing the drain, I would try snaking and flushing the existing 1.5" pipe with high pressure providing the 3/4" pipe can temporarily be removed to do so.
    I'm guessing that you are not tapping into the condensate line, that you are running parallel to it. Remember that you need to have a proper air gap.
  5. ditttohead
    Jan 9, 2012
    Ontario California
    The 1-1/2" condensate drains tend to get a lot of bio fouling in them. Condensate is usually almost purified water, no chlorine, no oxidizing agents. We have opened many AC drains to find the thickest, nastiest bio slime build up. looks like an elephant sneezed in your pipe. Ice maker drains do this a lot too. You should be able to clean it easily.
    The 2 cu. ft. system should have a 3.5 GPM DLFC button assuming your water temperature is normal.
Similar Threads: Slow drain
Water Softener Forum, Questions and Answers Hach 5B testing very slow Nov 17, 2016
Water Softener Forum, Questions and Answers Please explain Brine SLow Rinse cycle Jul 9, 2013
Water Softener Forum, Questions and Answers brine/slow rinse question Nov 21, 2011
Water Softener Forum, Questions and Answers What Causes the Brine Draw to be Very Slow in Water Softener? Apr 2, 2011
Water Softener Forum, Questions and Answers Slow Brine fill on new Fleck 7000SXT Sep 4, 2009
