slow drain toilet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gkirby, Jun 9, 2008.
  1. gkirby
    gkirby New Member
    Jun 9, 2008
    When flushing my toilet the water fills all the way up to the brim then drains very slowley. The soild waste does not drain with one flush. I have tried using a plunger, a snake and even one of those CLR power flush. It drains better after the power flush but goes back to slow drain shortly after, any ides.
  2. hj
    toilet
    Two ideas. Either the toilet is plugged or the main sewer is. Plunging or water jetting it is usually ineffective and can make the stoppage worse by packing it tighter. A plumber may be your best option unless you wish to spend time and money trying to do it yourself, and then might still need a plumber.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    If you're very lucky, it's the toilet. It's not a difficult DIY project to pull the toilet, check it out and clear the trapway if that was the problem, and reset it. If it's not the toilet, then see HJ's post above. Odds are it's not the toilet, but that's my non-professional opinion.
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I would immediately suspect something caught in the trapway, or a broken section of china in the trapway that floats to stop the flow.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would try a closet auger before I ever pulled a toilet!
Similar Threads: slow drain
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Yesterday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Bubbling Toilet and Slow Tub Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Kitchen Sink slow drainage Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Moved and replaced sink. Now slow draining Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Bathroom sink started draining slowly Dec 6, 2015
