Slope in pvc drains
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ehlinn, Jan 31, 2005.
  1. ehlinn
    ehlinn New Member
    Jan 26, 2005
    Maryland
    I have a general question about the maintaining the slope in pvc drains. I am running a length of "horizontal" drain to a vertical line and I will be making the connection with a T. But the t comes off the vertical at 90 degrees. How do I slope the horizontal run of pipe going from my drain to the T? Do I just force it to have the 1/4 inch per foot slope? Sorry if this is a little unclear, it is awkward to explain. I just don't want any leaks. Thanks for any help.
    Eric
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Slope in PVC drain
    You won't have to actually "force" the PVC to make the 1/4"/ft slope. PVC is flexible enough to conform to the trench.
  4. hj
    tee
    If you were using threaded pipe and fittings, the tee would be tapped so that the "pitch" is automatic. PVC and ABS fittings have enough flexibility that you can put the proper pitch, and a lot more if necessary, without affecting the integrity of the joint.
  5. ehlinn
    ehlinn New Member
    Jan 26, 2005
    Maryland
    Thanks for the info.
Similar Threads: Slope drains
Plumbing Forum, Professional & DIY Advice Proper drain slope on short run Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Need Advice for Maximum slope and clean out location Apr 19, 2016
Plumbing Forum, Professional & DIY Advice Negative Pressure in Drain, Backwater Valve, Zero Slope Nov 27, 2015
Plumbing Forum, Professional & DIY Advice Quick toilet drain slope question Aug 24, 2015
Plumbing Forum, Professional & DIY Advice Adjusting DWV slope basement shower Jul 10, 2015
