SLOOOOOOW Bathtub drain
Discussion in 'Shower & Bathtub Forum & Blog' started by leettema, Oct 25, 2004.
  1. leettema
    leettema New Member
    Oct 24, 2004
    The bathtub in our second floor drains slower that molasses. The only thing I've really tried to access it with is this plasic strip with barb hooks on it that I have used successfully in the past to clear two teenage girls hair from the drain. I can snake this thing down quite a way and am not getting anything. I've also tried plunging it some with no luck. I'm pretty sure it's just a hair clog somewhere but I don't have a clue as to how to clear it. It seems like the only thing I can remove is the little cover on the top of the drain. This is what I remove to snake the strip down.
  2. Bob's HandyGuy
    Bob's HandyGuy Senior Member
    Sep 10, 2004
    Forget the plastic strip. Get yourself a rotating hand auger. Push it into the drain until you feel resistance, rotate the auger until it moves through the bend, repeat until you've cleared it to the main line. Keep the auger close to the drain all the while and have a little water running as you do all this. Pull it out slowly, rotating it and moving it into and out of the drain. The auger costs about 25 bucks but you can use it again and again. It will pay for itself the first time it opens a drain.
  4. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    At least you didn't put any chemicals down the drain :)
    Plastic strips and hand crank snakes rarely/only work if the restriction is very close to the drain strainer.
    The best long term remedy is to have the bathtub drain line snaked and cleaned with a power machine, then use a hair snare over the tub drain outlet to help prevent future clogs.
Similar Threads: SLOOOOOOW Bathtub
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Thursday at 10:03 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Bathtub Mortar - Should I be worried? Feb 13, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Bathtub/shower enclosure product choices Jan 26, 2017
