Sloan Flushometer
Discussion in 'Toilet Forum discussions' started by canton, Jan 31, 2006.
  1. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    I just installed a Sloan Flushometer model #1111 on a floor mounted toilet. It was a 1" feed coming out of the wall, my only problem is that the tailpiece which connects to the spud seems a little insecure, and I tightened it down pretty hard. My question is has anyone else experienced this problem with these flushometers?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    That 1" supply nipple should be anchored really well inside the wall.
    Does the tail piece fit deep into the spud?
    I think if you get a lot of movement it's because it's loose at the supply side.
  4. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    Sloan valve
    As far as I can remember I pushed the the tailpiece down inside the spud as far as it can go. However I did not secure the 1" line, it seemed to be secure enough. It (1" line) was only going about a foot before it 90'd off and was secured after that. I still think that the owner should put a automatic sensor on this sloan valve, because people will continue to use their foot to flush. Unfortunately the automatic sensor cost $300.00.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I agree with that. People can be rough on Sloan valves...........
Similar Threads: Sloan Flushometer
Toilet Forum discussions Flushometer Sloan Gem-2 - Help needed Apr 18, 2012
Toilet Forum discussions HELP!! I can't flush my Sloan Flushmate (Gerber) toilet!!! Jun 20, 2014
Toilet Forum discussions Sloan Flushmate III recall Jun 21, 2012
Toilet Forum discussions Replace Sloan Flushmate in Crane Bowl with Gravity Fed Parts? Mar 20, 2011
Toilet Forum discussions Sloan flushmate won't stop running Nov 11, 2010
