Slip Nuts vs. Welded PVC
Discussion in 'Shower & Bathtub Forum & Blog' started by RenePF, Sep 13, 2010.
  1. RenePF
    RenePF New Member
    Sep 13, 2010
    Attorney
    Chicago IL
    I am replacing a bathtub. The typical drain assemby uses slip nuts rather than solvent welded PVC pipe. It seems to me that welded PVC would be a better and more reliable method. What is recommended and why.
  2. Terry
    Aug 17, 2004
    Codes now prefer the solvent weld waste and overflows for tubs.
    The slip joints can leak.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Sometimes you just have to believe your gut feelings when you look at a product and it seems cheesy...
  5. hj
    With the glued drains you only get ONE chance to do it correctly.
  6. RenePF
    RenePF New Member
    Sep 13, 2010
    Attorney
    Chicago IL
    Thanks to all the responded. I think I am going to try the pvc weld path. I feel more confident in it. I have existing brass parts and may combine it with Fernco rubber adapters and pvc. Okay?
Similar Threads: Slip Nuts
Shower & Bathtub Forum & Blog Washer for 1-3/8 Slip Nut Mar 1, 2017
Shower & Bathtub Forum & Blog Slip-on tub spout w/ diverter recommendation? Sep 20, 2016
Shower & Bathtub Forum & Blog Leaking slip over bathtub faucet Aug 26, 2016
Shower & Bathtub Forum & Blog 3/4 copper stub..need a tub spout diverter that will slip on Sep 8, 2015
Shower & Bathtub Forum & Blog Adding non slip surface to shower for older person Sep 1, 2014
