sliding doors
Discussion in 'Shower & Bathtub Forum & Blog' started by willl, Feb 17, 2007.
  1. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    Hi,
    I bought some shower sliding doors from a big box store and It didn't last that very long before rusting and falling apart. Is there any professional quality sliding doors online that one can buy? What store or brand should I look at? If you can help then thanks.:cool:
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Sliding Shower Doors
    All the sliding doors I've dealt with look beautiful when you first install them. After a few years, they all seem to get tarnished, mildewed, and ugly. I would stay away from them like the plague.
  4. jimbo
    jimbo Plumber
    What brand did you buy and how much did you pay?
    I put my doors in about 8 years ago. Still look fine. You need to clean aluminum frames regularly, because it you let soap scum and minerals build up, you cannot get that off easily.
    Today, you would need to be spending in the $200+ range for a shower door. If you get a cheapy, then that's what you get. First thing is , you will have mill finish instead of polished aluminum, and that will be hard to keep clean,.
  5. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    I recommend frameless glass doors, that at least eliminates several hard to clean places. It also eliminates the seal between the frame and glass. You can expect to pay in the $400 - $500 range for these.
  6. willl
    willl New Member
    Jul 18, 2005
    North Dakota
    When I first bought the house they had some sliding doors in that lasted a good 9 years. Not to mention they where in the house when we moved in so I have no idea how long they were in before hand. The reason we replaced them was only because they were starting to look bad as verdeboy wrote. These new ones we put in lasted only 3 years before looking ugly AND the bottom that holds the glass piece in place has rusted through so cannot slide the door anymore without having the glass piece fall out:mad:.
    Perhaps the frameless as Dan Pick wrote is the way to go. Looks cleaner. Any good places online where I can just make the purchase. Anymore thoughts. Thanks
  7. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    wilson glass is good
    measure, measure and measure. Then calculate. Then share with others to verify. Wilson Glass will help you calculate.
    Finally you'll have the right order and you can install it yourself.
    david
  8. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    I've seen several in **** Stores in doing searches for frameless glass bypass and pivot doors. I will probably be purchasing from one of these stores when I get the basement shower completed. I would probably go with a 3/8" door
    Good Luck
Similar Threads: sliding doors
Shower & Bathtub Forum & Blog Frameless sliding glass doors leaking Oct 4, 2011
Shower & Bathtub Forum & Blog Looking for good quality fiberglass/acrylic shower base and sliding doors Nov 2, 2010
Shower & Bathtub Forum & Blog "totally" frameless sliding shower doors Jul 16, 2008
Shower & Bathtub Forum & Blog Non-Sliding Tub Doors? Feb 19, 2006
Shower & Bathtub Forum & Blog Sliding Glass Shower Doors Oct 17, 2005
