Sleeving PVC for concrete pour?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cacher_chick, Mar 29, 2011.
  1. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    When one pours a slab over a rough-in, what is commonly used to sleeve the drain and vent pipes where they are coming up though the slab?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Coming up through the slab doesn't require a sleeve but going through a footing does.
    John
  4. Terry
    Aug 17, 2004
    Some places will require a sleeve on the pipes in the flat work. They didn't in the past.
    I've seen cardboard, bubble wrap, closed cell foam, whatever works.
  5. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Plastic drainage systems require provisions for contraction/expansion...if you cement your stacks in place you've partially interfered with that.
    There is a proper product for sleeving a pipe through a slab/footing, but for your purposes, it's easier to wrap the stub several times over in sill plate foam gasketing.
  6. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I used some sill gasket material and tape around my w/c drain, to make sure the socket on the closet flange had enough room to bottom out.
  7. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    On big jobs i buy the half roll roofing paper, otherwise I just use the cardboard wrapper from the rolls of soft copper. The cardboard works ok but the roofing paper looks more proffessional and is easier to wrap.
  8. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Very glad you asked this question. I very rarely do new construction plumbing but have a complete job to do this week. In the past I've had lots of problems getting toilet flanges to sit down flush and level because the concrete pours against the pipe and when possible I'll use a flange which will slip inside the pipe or fitting. Most of the time the concrete guys do not get the concrete flat around the stub out. It's not unusual for me to have to use a hammer drill to take out the concrete around the pipe to get the flange to install properly. Sure as heck makes a log of seemingly unnecessary work.
  9. Terry
    Aug 17, 2004
    I haven't been asked to sleeve around the water closets. I like to stub up with 4", that way they can pour concrete around the pipe and I can still glue in a closet flange on the inside. I just cut the pipe flush before installing the closet flange.
    I use a 4x3 closet bend below.
  10. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    We use roofing paper as well.
Similar Threads: Sleeving concrete
Plumbing Forum, Professional & DIY Advice Sleeving a sewer line in a condo Dec 14, 2011
Plumbing Forum, Professional & DIY Advice Sleeving copper water main Jul 30, 2010
Plumbing Forum, Professional & DIY Advice Sleeving Pipe to Garage Sep 25, 2009
Plumbing Forum, Professional & DIY Advice Plastic Sleeving for copper pipe Mar 4, 2009
Plumbing Forum, Professional & DIY Advice Sleeving of damaged cast iron pipe in slab Feb 26, 2009
