Skirted TOTO how to change seat
Discussion in 'Toilet Forum discussions' started by AgentK, Feb 11, 2012.
  1. AgentK
    AgentK New Member
    Feb 11, 2012
    New York
    In an earlier thread http://www.terrylove.com/forums/archive/index.php/t-29151.html I learned that my Bemis seat was installed incorrectly, using the plastic bolts supplied with the seat, rather than the proper Toto plugs If I remove the bolts from above, the nuts will fall inside the skirt. Is there any potential harm in that, or can I just "let the nuts fall where they may?". I will install the new seat with the proper TOTO anchors, of course.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    There is nothing it could hurt. But you may have a problem removing the existing bolts with no way to hold back on the nut. You may be able to loosen them enough to be able to cut them off and let the remainder drop. They'll be waiting for you when you some day have to pull the toilet.
    John
  4. AgentK
    AgentK New Member
    Feb 11, 2012
    New York
    Thanks. By lifting up the seat as I loosen the bolts, they seem to hold by friction underneath. Good
    suggestion to cut them if I can only get part
    way.
    [​IMG]
  5. Terry
    Aug 17, 2004
    If you needed to get underneath, it's a simple matter of;
    Turn off and disconnect water supply,
    Aquia, remove the two side screws and lift off.
    Other skirted bowls, remove the velcro'ed panels, remove the nuts and washers and lift off.
    [​IMG]
Similar Threads: Skirted TOTO
Toilet Forum discussions Maintenance on Skirted Toilets like Toto Carlyle II Sep 17, 2015
Toilet Forum discussions Instal Toto eco soiree (skirted) if water line is 5.5inches from center? Jul 28, 2015
Toilet Forum discussions Skirted Toto with Drake performance? Jan 3, 2014
Toilet Forum discussions Toto skirted toilets and existing waterline location May 23, 2013
Toilet Forum discussions Toto Skirted Toilet - Rough in Tolerances May 12, 2012
