Sizing irrigation pump and tank with unknowns?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Rod M1, Mar 18, 2012.
  1. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
    At the moment I have a new 1 1/4 driven well with the known spects bellow. I'm planing on installing a sprinkler system in the next several years but for the moment will be using 2 oscillating sprinklers at the same time. I'm looking at the Goulds J7S or J5SH. With this information can you make a pump suggestion? We had a old pump with 1/3HP that seemed to be inadequate for any task (screen plugged up 60's pump).
    area to be covered 80ftx30ft and 50ftx40ft
    gallons per minute using the 1/3hp pump about 6 to 7 gallons per minute
    static water level: 11.5 feet
    well screen: 3 feet 80 gage
    total depth: 23 feet
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Either one of those pumps will work, and put out more than the old 1/3 HP. However, if the well doesn't make as much water as those pumps put out, or if you are not using as much water as those pumps put out, you will need to do something like a CSV to keep the pump from cycling on and off.
  4. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
    What model of CSV would you recommend? Will the 4.4 gallon tank work for this?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
Similar Threads: Sizing irrigation
Pumps and Tanks Well Forum & Blog. Water is life. Water Softener Sizing (Flow Rate) Feb 2, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well pump sizing check: Feb 2, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sizing a pipe from pump to house 250 feet apart Oct 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump sizing and info on Franklin / Schaefer pump 3200 Series Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New well pump sizing Aug 20, 2016
