Sizing a new well pressure tank.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cwilliams2000, Mar 17, 2013.
  1. cwilliams2000
    cwilliams2000 New Member
    Mar 17, 2013
    Boston
    I currently have a Pro Source "50" gallon tank which I believe holds much less than that and my house has a lot of bathrooms, plumbing, etc and I have irrigation. I always have thought that it cycles quite a bit, I haven't checked the pressure but don't think it's that as much as the demand. One page I read said, buy the biggest tank you can afford and fit, and then another said this is a bad thing.
    I also have a pinhole leak on the manifold coming off the tank and have made some other upgrades so thought it might help my pump life and would be easier to replace the tank and manifold.
    The tank I looked at was a extrol 82 or 86 gallon, does this make sense? Or is bigger not better?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  4. cwilliams2000
    Mar 17, 2013
    Boston
    I think I am having a hard time understanding how they work, it looks like they restrict flow to match what is being drawn and sounds good, but it would seem that the pump was intended to pump at full flow, not be held back, maybe I am missing something?
  5. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    It's just artificial head pressure. no different than if the pump were working from a deeper water level. wellxtrol is good tanks.. the pro source not so much.
  6. Kevin Thomas
    Kevin Thomas New Member
    Mar 24, 2013
    Michigan
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I hear you on that one! The CSV is a simple product with a complicated explanation. Back in about 1995, I just started putting a CSV on every well system. I didn't even explain it anymore, that is just the way we did it from then on. Sometimes I would get a question about the small tank. I would just say I am happy to change it out to the old big tank type system, it will just reduce your warranty from 5 years to 1 year. Rarely did anyone want to go back to the old way fo doing things, especially after they had a few days of good constant pressure in the house.
    Best thing is to let them play with this graphic. http://www.cyclestopvalves.com/simple/home.php
    These kinds of things were not available 20 years ago.
Similar Threads: Sizing pressure
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank sizing. Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well pressure switch sizing Jan 27, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New member's questions. pressure tank sizing Nov 16, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Sizing/Replacement Dec 18, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Water Softener Sizing (Flow Rate) Feb 2, 2017
