Pacman
Hello,
I am helping redesign a relative's water treatment system. I'd appreciate your comments and suggestions.
Right now they have a cartridge sediment filter and water softener (Eco); both are 20 years old. The softener uses a time clock for regeneration, doesn't soften down to zero anymore, back washes frequently (to keep up) and uses a lot of salt. They also have red/brown staining problems on fixtures and laundry. We've decided to start fresh.
A. Our goals for the new system are:
(1) meter based regeneration
(2) user-friendly, non-proprietary system
(3) reduce staining
B. Water Conditions:
Private Well (approx. 100' deep)
Hardness: 77.4 gpg
Sodium: 298 ppm
Calcium: 357 ppm
Magnesium: 105 ppm
pH: 7.65
Sulfate: 1920 ppm
Iron: 0.64 ppm
Manganese: 3.220 ppm
There is a rotten egg/hydrogen sulfide smell from time to time.
In addition, fine sand and "rust flakes" are also a problem (the cartridge filter catches these).
We realize this is very hard water. The current system has done a good job of taking care of the hardness during it's life, but not the iron and manganese.
C. Household Conditions:
2 people (3 on weekends)
1 bathroom (possible 2nd in a few years)
D. Planned Solution:
(1) Cartridge sediment filter to catch the sand and other sediment
(2) Katalox Light back washing filter to remove the iron, manganese and hydrogen sulfide - size to be determined
(3) Water Softener - Fleck 7000SXT 2.5 cu. ft
To maximize salt efficiency, I plan to set the unit to 50K capacity and use 6 lbs. salt/cu. ft. This means the system will regenerate approx. every 5 days.
My Questions:
(1) How do I calculate the size KL filter I need to use? What should I factor into the calculation? service flow, iron, manganese levels?
(2) What are the downfalls of a KL filter? They almost seem too good to be true (when compared to other iron/manganese removal options). Is it worth the cost for our water conditions?
(3) How often should KL be back washed?
(4) Is it worth it to up-size to a 3.0 cu. ft. softener? The larger the unit, the harder I think it will have to work to backwash because of the increased resin volume.
(5) Can the 7000SXT be set to up-flow brining?
(6) I've had the 5600SXT before and really like the valve, but I think the soft water brining offered by the 7000SXT is worth the upgrade since our raw water is so hard. What are your thoughts?
Thank you
(3) reduce staining
Hardness: 77.4 gpg
Sodium: 298 ppm
Calcium: 357 ppm
Magnesium: 105 ppm
pH: 7.65
Sulfate: 1920 ppm
Iron: 0.64 ppm
My Questions:
Thank you
