Size of water line to Drake toilet/
Discussion in 'Toilet Forum discussions' started by bg, Mar 14, 2008.
  1. bg
    bg Member
    Mar 3, 2008
    Will I be able to use a 3/8" braided supply line for this new
    Drake I just received ? It's the base elongated model CST744S.
    Thanks for any info.
    bg
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    absolutely
  4. hj
    supply line
    It makes no difference what kind, or size, supply line you use. That water only refills the tank. The water IN the tank does the flushing, not the water coming through the supply line.
  5. Terry
    Aug 17, 2004
    Just make sure you don't use a Watts FloodSafe supply.
    The Watts FloodSafe will shut its self off before the tank fills.
    [​IMG]
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    And, since you only use 1.6 gallons or less to refill the tank, a 3/8" line will still fill the tank quickly.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    I have seen homes flooded because a Watts Floodsafe broke!:mad:
    Bad News!
    [​IMG]
  8. bg
    bg Member
    Mar 3, 2008
    Thanks all. I guess you can tell I'm pretty new to this toilet
    business. I ended up getting one of these. I hope it'll do.
    The shutoff is a floor mount. I screwed up when I ordered
    the Drake toilet. I thought I had ordered the SL version
    which is a 16.5 height bowl. I ended up with the S version
    which is 14 5/8". To send it back is too cost restrictive for
    me right now. Is this 20" going to be too long ? I bought
    it think I was getting the 16.5 version bowl at the time..
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=25114-104-BKSPCT20614C&lpage=none
    I promise I'll learn this stuff if you folks don't mind helping.
    I grateful for the info...:)
    bg
  9. hj
    supply
    They are never "too long" but they can be "too short". Just loop it before it connects to the tank.
  10. bg
    bg Member
    Mar 3, 2008
    Thanks for the reply. I appreciate it..
    bg
  11. Gary Swart
    Sep 1, 2004
    Yakima WA
    If you really want the ADA model, you could probably sell the one you have for close to what you paid for it. ADA height is great for any one getting to an age where the knees don't life as well as before and for anyone of medium height like 5'8" and up. Kids and petite folks would probably prefer the standard size.
  12. bg
    bg Member
    Mar 3, 2008
    Thanks for the suggestion. Will consider it.
    bg
Similar Threads: Size water
Toilet Forum discussions water spot size? Sep 8, 2012
Toilet Forum discussions A simple question: are the water lines that go to the toilet tank all the same size? Jul 13, 2011
Toilet Forum discussions Is water spot size affected by flange diameter? Dec 28, 2008
Toilet Forum discussions Kohler Cimarron normal water spot size Oct 19, 2005
Toilet Forum discussions Toto Entrada and rough size Jan 19, 2017
