Size of neoprene gasket on CI drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TJanak, Nov 4, 2011.
  1. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    I have a washing machine drain that exits the side of the slab as cast iron. There is a neoprene gasket with a female threaded adapter into the gasket. The gasket is a Ty Seal 2 SV. Does this mean this is 2" CI pipe or a 2" hub? The OD of the CI around the gasket was about 3.5". Honestly the pipe ID looks like 1.5" and I was hoping it was 2" since I need to do some repairs and all new work needs to be 2" from what I've read.
    What's interesting is the washer standpipe is 1.5" galvanized leaded into what appears to be 2" CI above the slab. The CI was ~2.3" OD so I figured that was 2".
    The female threads at the oustide of the house slab had a 1.5" thread to barb fitting with 1.5" poly pipe.
  2. jadnashua
    Drain pipe is typically measured ID, so a 2" pipe should measure 2" on the ID. Wall thickness is fairly consistent with plastics, but not as much with CI. So a 2" pipe is normally around 2.5" OD or so, give or take a little.
  4. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    Jim, I can't measure the inside of the pipe where it exits the slab so I'm trying to determine its ID based on the neoprene gasket saying Ty Seal 2 SV. The pipe is full of crud so it's hard to guess the ID. Probably need to get it cleaned/augered.
    After looking around, is there even such a thing as 1.5" CI or would it have to be 2"?
    After looking some more, looks like a threaded ferrule for 2" CI pipe would have a 1.5" tap size. Which is what I have.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It's 2" SV cast iron. There is no 1 1/2 CI
  6. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    Thanks Tom.
    Can I pry out the threaded ferrule or do I need to cut it to get it out? The threads are pretty much gone so I was going to put 2" pvc into the Ty seal.
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Tom there is 1 1/2 Cast Iron, but in No -Hub, there is no service weight 1 1/2" cast iron though.
Similar Threads: Size neoprene
Plumbing Forum, Professional & DIY Advice Sillcock Pipe Size with New PEX Yesterday at 6:57 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink in laundry room drain size issues Tuesday at 7:08 AM
Plumbing Forum, Professional & DIY Advice Pipe Sizes for Older Water Meter Horn Sunday at 7:40 PM
Plumbing Forum, Professional & DIY Advice Getting a tankless water heater installed, but have questions on piping size Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Silly question regarding toilet water supply line -- what size? Feb 28, 2017
