Hi,
My washer discharges to a 42" high 1.5" diameter vertical drain pipe. There's a P trap at the bottom of this pipe, and then the drain runs horizontally (1/4" drop per foot) for about 5ft and then discharges to a 4" diameter pipe that goes through the basement wall and to a drywell outside.
I want to also send my 3/4" dia watersoftener drain to this same 1.5" diameter vertical drain pipe. I plan to have an air gap by adding a wye (see sketch).
1. is my air gap solution acceptable?
2. is this all too much flow for a 1.5" pipe? I can't find any references for what's allowable/acceptable.
Thanks for your advice.
Regards,
Theodore
Regards,
Theodore
