size hole for single hole faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bobbieK, Apr 13, 2009.
  1. bobbieK
    bobbieK New Member
    Apr 13, 2009
    I am installing a vessel sink faucet in a new counter top. I have the spec sheet for the faucet and i does not indicate what size hole to drill. I phoned the company and they said they do not recommend a size, and that my installer will be able to tell from the spec sheet. Unfortunately, i am the installer and i have no idea how to tell from the spec sheet. I hope the link below works.
    thanks in advance for any help
    http://www.*********.com/catalog/pdfImages/1a/1a2bbe3b-b4d8-4090-90cd-7dc7904177a1.pdf
  2. jadnashua
    Most faucets call for a 1-3/8" diameter hole. Safest thing to do (if you have the faucet), is to drill a hole that size in a piece of scrap and see if it fits well, covers the hole with the body, and you can anchor it properly. Adjust, if required, and then drill the counter.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Evidently you were linking to a sales link the forum filter doesn't like.
    I would say that checking on the manufacturers website should yield the installation information you need.
    Jadnashua is correct that is the common size used.
  5. bobbieK
    bobbieK New Member
    Apr 13, 2009
    thanks!
    I will use the "drill a hole in a scrap" method :) great idea, wish i thought of that.
    I was unable to get the information from the manufacturer on the phone or on their spec sheets from the website. I guess not all manufacturers are created equal.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    That is correct.
    I personally like Delta and Moen...
  7. hj
    faucet
    A vesel sink faucet would not have a pop up drain rod, so you should be able to measure the shank and drill a hole the proper size.
Similar Threads: size hole
Plumbing Forum, Professional & DIY Advice hole size for typical single hole faucet? Dec 19, 2014
Plumbing Forum, Professional & DIY Advice Hole size retrictions for blocking between floor joists? Jan 13, 2013
Plumbing Forum, Professional & DIY Advice Access to tub faucet - size of hole in drywall? Nov 7, 2012
Plumbing Forum, Professional & DIY Advice Hole size allowed in 2 X 8 joist Feb 7, 2008
Plumbing Forum, Professional & DIY Advice Repairing dime-sized hole in 4" CI pipe Jul 19, 2007
