Sink trap - making 1 1/4 inch connection 1 1/2 inch
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by fsrph, Dec 5, 2013.
  1. fsrph
    fsrph New Member
    10
    Pennsylvania
    Hi,
    I am trying to replace a bathroon sink trap in the easiest way for me. I am not very knowledgable in plumbing and found this product - http://www.fernco.com/plumbing/residential-plumbing/flexible-qwik-traps . Installed it OK with one problem. The pipes on both sides of the trap are 1 1/4 inch. However the flexable trap looks like one side is made for 1 1/2 inch pipe. When I tighten the clamp on this side it leaks - the leak is very small but it does leak. Is there a way I can convert the very end of the pipe to 1 1/2 inch so the quik trap can slide over it and adhere tightly to it? Thanks.
    Francis
  2. Reach4
    Reach4 Active Member
    2,065
    If you look at the description, the unit should come sized for 1-1/4, and you can cut off the leading bit to get to the wider part which fits 1-1/2. Maybe you bought a return where somebody had cut off one end already.
  3. fsrph
    fsrph New Member
    10
    Pennsylvania
    Good thought but the package was sealed and it looked new. Are you saying BOTH ends of the product are set up for 1 1/4 inch pipe? Because mine definetly is not. Thanks.
  4. fsrph
    fsrph New Member
    10
    Pennsylvania
    I received a reply from the manufacturer (se below) that this product connects to the sink by
    1 1/4 or 1 1/2 inch connection but the outflow is for 1 1/2 inch pipe. THey recommended an adapter to make it work.
    "The FT-150 is made to connect 1 ¼ or 1 ½ sink drain to 1 ½ drain pipe. Your only option would be to use a 1056-150/125 coupling to put in a stub of 1 ½ pipe to connect it to."
  5. hj
    26,481
    quote; THey recommended an adapter to make it work.
    You are already using a "piece of c***/ garbage", so why would you want to compound the "fix" by adding additional questionable components to make it "work"?
  6. Terry
    14,889
    Just pick up a real 1-1/4" p-trap and the proper slip joint nut and washer at the wall.
  7. fsrph
    fsrph New Member
    10
    Pennsylvania
    I planned to do what you suggested but was unable to proceed. The nut where the trap pipe enters the wall was broken. I can't put the nut on unless I somehow remove the pipe going into the wall to slip it on. This is how I came to use the "cheap" solution as it was the only way. I'd much rather have a chrome p-trap.
    Francis
  8. jadnashua
    21,888
    Unclear exactly what your situation is, but if there's a broken off piece of pipe in the wall fitting, it can be removed, then a new trap can be installed fairly easily. Maybe a picture of what's there now would help clarify and offer a better solution.
  9. fsrph
    fsrph New Member
    10
    Pennsylvania
    Pictures added. No broken piece of pipe. The nut was broken on the far side of the p-trap. In order to install a metal p-trap I need to slide the nut on the far side of the pipe that goes into the wall. The pipe is attatched to the wall. I have no way to slide the nut on. The nus had to be put on on the side of the pipe where the escutcheon is. That is my problem. I'd much rather have a metal p-trap that the one I'm using. Thanks.
    Francis
      File size:
      64.1 KB
      266
      File size:
      58.5 KB
      260
  10. fsrph
    fsrph New Member
    10
    Pennsylvania
  11. jadnashua
    21,888
    Still can't see how that piece that goes into the wall is attached...
Similar Threads: Sink trap
Plumbing Forum, Professional & DIY Advice, Tips & does double kitchen sink require two traps? Sunday at 8:31 PM
Plumbing Forum, Professional & DIY Advice, Tips & P trap issue in bathroom sink Aug 10, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Fixing S-trap under kitchen sink Aug 7, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Kitchen Sink Trap in Basement Apr 2, 2014
Plumbing Forum, Professional & DIY Advice, Tips & sink sewer gas with p trap Apr 1, 2014
