Sink Location
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Joe HomeOwner, Nov 20, 2004.
  1. Joe HomeOwner
    Joe HomeOwner New Member
    Nov 20, 2004
    Hi there I am currently developing my basement, framing and electrical are completed, now I have to do the plumbing. My question is about the location of where I (my wife) want the sink to be in the bathroom. To put the sink in the desiride location I would need to run the drain pipe 4' from the stack make a 90 degree corner and then run the pipe another 3' to where the (pedestal) sink is to be and then another 90 degrees to meet the trap on the sink. Of course I need this to pass inspection in Alberta.
    Unsure Joe
  2. jadnashua
    For the horizontal stuff, you need 1/4" per foot slope (you can translate that into metric yourself! sorry). If that is doable, then you also need to account for a vent - that may be harder. The vent can't be too far from the back of the sink. Not sure what the actual distance is, especially to meet the codes in Alberta (lovely place - had a nice time in Calgary and Banff a few years ago). I don't think the angles are a big problem, but somebody else will comment. If you could avoid one, that might help, but I don't think it is a killer.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    1/4" us just slightly more than 1 cm, so you would need about 1 cm slope per 30 cm. If possible, use long sweep elbows for the 90's.
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    More of the above
    For the 7 foot run, slope needs to be 7/4", 1-3/4". That's 5 cm.
  6. hj
    vent
    The location of the vent will depend on your plumbing code requirements, but more than likely you will have to make a vent connection within 4 feet of the actual trap and then route it back to the vertical stack "parallel" (both lines will have to pitch to the vertical pipe connections), to the drain pipe, but at least 42" above the floor.
  7. Joe HomeOwner
    Nov 20, 2004
    Thanks for the replies guys, even though most things up here are in metric most of the trade world still uses imperial. I was trying to interpret the Canadian Plumbing Code but reading that is like reading ancient Eqyptian it just does not make any sense without a translator (lawyer) around. Once again I appreciate the replies.
    Take Care EH!
    Joe
Similar Threads: Sink Location
Plumbing Forum, Professional & DIY Advice Flip-flop toilet and sink location in small bath - need to mess with vent pipes? May 18, 2016
Plumbing Forum, Professional & DIY Advice Sink Vent near window through roof or path to old location Mar 27, 2016
Plumbing Forum, Professional & DIY Advice San Tee location for drop in bathroom sink? May 31, 2014
Plumbing Forum, Professional & DIY Advice Relocation of new kitchen sink Mar 9, 2014
Plumbing Forum, Professional & DIY Advice Relocation of kitchen sink Mar 9, 2014
