Sink fitting in new granite countertop question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by richrc1131, Oct 18, 2012.
  1. richrc1131
    richrc1131 New Member
    Apr 16, 2008
    Central Connecticut
    I hope this is the right thread for this. Sorry if it isn't.
    I just had a granite counter top installed. The contractors for Home Depot I think cut the sink cutout too wide. My wife measured it (I am still at work) and said that there is only about a half inch of material under the lip of the new sink holding it up.
    I don't know much about plumbing but I feel that there should be more. Thoughts?
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    A half inch is plenty. Granite is pretty strong stuff ... almost like rock, y'know.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Sounds like you are OK! But you dodged a bullet! NEVER order a hole cut or drilled in granite until the granite guy has the sink or faucet IN HIS PAWS!!!
  5. richrc1131
    Apr 16, 2008
    Central Connecticut
    I did supply them with the sink ahead of time.
  6. richrc1131
    Apr 16, 2008
    Central Connecticut
    Ok here are the measurements:
    counter area:
    25" deep (not including back splash area)
    cutout:
    7/8 of an inch clearance from the back splash
    24 1/4" wide
    21 1/14" deep
    2 3/4" from the front of the counter
    sink:
    basin is 21" wide
    15 1/4" deep
    4 3/4" faucet area
    sink perimeter:
    25" wide
    22" deep
  7. richrc1131
    Apr 16, 2008
    Central Connecticut
    I guess my main concern is that they said in an email that they would be drilling for the faucet and handles on site, but they didn't. They just cut a bigger hole.
    I am worried that the bigger hole isn't as strong as had they drilled for the faucet and handles like they said they would.
  8. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    If the faucets are sink-mounted, why would they be drilling the granite? That's NEVER done. Whoever told you different
    must not have been familiar with the details of your job.
  9. hj
    Typically, the cutout is 1/2" to 3/4" smaller than the sink so yours is the right size. The only time a sink has faucet holes and the countertop is drilled for them is when the sink in undermounted. The sink should have had ribs under the ledge which have made it impossible to just cut the opening the size of the bowl, and would have done nothing to strengthen the installation. Your sink will break before the countertop would. They did it the "proper" way, based on your description.
Similar Threads: Sink fitting
Plumbing Forum, Professional & DIY Advice Will this kitchen sink drain fitting fit? May 8, 2016
Plumbing Forum, Professional & DIY Advice Two Bathroom Sinks Back-To-Back. What Double Fitting To Use On Horizontal Drain? Dec 8, 2015
Plumbing Forum, Professional & DIY Advice Major issues fitting new drain to bathroom sink. Nov 15, 2015
Plumbing Forum, Professional & DIY Advice PVC to ABS fitting leaking under kitchen sink - why? Apr 26, 2015
Plumbing Forum, Professional & DIY Advice Sink and Toilet Fittings Apr 1, 2015
