Sink drain rough-in... to 1960's era male threaded bronze?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dfv2, Aug 2, 2010.
  1. dfv2
    dfv2 king overbudget
    Aug 2, 2010
    mechanical engineer
    Upstate NY
    Nice forum! Been lurking a while, finally needed to register and ask some questions. My name is Steve and I've been renovating my 1960's ranch bath for the last month (yes, month).
    FINALLY, I'm trying to decide what to use for my sink drain. Stubbed out from the wall is the original male threaded 1-1/4 fitting, soldered to 1-1/2 copper which runs to a 4" copper drain/vent stack.
    Should I go PVC or brass (chrome plated stuff)? Would you guys typically connect to the threaded fitting with an extension, and a nylon washer/screw ring? I'm a little lost on this type of plumbing and need some suggestions. If needed I'll take a pic. FYI this will all be hidden within a vanity so no issues with it looking overly pretty.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would just use the 1 1/4" plastic tubular as long as the pipes are in the correct location for your vanity...
    If they are not in the correct location they should be moved before hand...
  4. dfv2
    Aug 2, 2010
    mechanical engineer
    Upstate NY
    thanks! I was watching holmes on homes, and his plumber guy was using a fernco to transition from the copper stub-out to abs. I just want a worry-free connection as I won't see a leak until it damages a LOT of stuff back there.
Similar Threads: Sink drain
Plumbing Forum, Professional & DIY Advice kitchen sink in laundry room drain size issues 34 minutes ago
Plumbing Forum, Professional & DIY Advice One side of kitchen sink not draining Friday at 7:17 AM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Drain design with stack in middle of 2 sinks + washer Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
