Sink Drain Nut
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Eddie_T, Jul 5, 2012.
  1. Eddie_T
    Eddie_T New Member
    Jun 28, 2011
    Brevard, NC
    I have a triple basin Elkay Cuisine Decor stainless steel sink which uses a thin zink nut to hold the cup assy (my terminology) and drain to each basin. The first nut failure was on the left (most used) basin. I have been unable to find nuts locally (Ace and Lowe's). I tried a 1.5" conduit lock nut but it didn't have enough threads and will jump a thread after a while apparently due to expansion with hot water in the basin. The nut can only be about 1/4" thick as the remote controlled drain has to thread onto the tailpiece below it. I tried making a nut by grinding the crown off a plastic slip joint nut but its hard to cinch it tight enough to compress the rubber gasket between the cup assy and the basin. A second nut (on the center basin) has now broken so I would like to replace all three. I don't see them online and if available postage would probably surpass the price of the nuts.
    Any suggestions, or any nuts from another discipline that might work? Brass would be nice but I can't find
    1.5" brass nuts either.
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Eddie_T
    Eddie_T New Member
    Jun 28, 2011
    Brevard, NC
    Thanks for the links.
  5. hj
    That type of drain typically has a "T" nut with a "sleeve" that goes through the drain's "bucket". The drain usually has a "rolled thread" which does not engage regular threads very well. The "sleeve" allows the nut to have additional threads without taking up space between the drain and the operator.
Similar Threads: Sink Drain
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice High Wall Drain, New Sink & Disposal Dilemma Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice WASHER DRAIN TO KITCHEN SINK TRAP Feb 12, 2017
