Single receptacle to a double receptacle
Discussion in 'Electrical Forum discussion & Blog' started by beeger11, Apr 30, 2009.
  1. beeger11
    beeger11 New Member
    Apr 30, 2009
    I have a single receptacle in my garage that is used for my sprinkler system. I would like to change it to a double to plug in my garage fridge as well. Is this ok to do? When I did it I noticed only one of each wire (black,white, green) coming out of the wall. Should I use a GFCI? Will this cause any problems?? Thanks
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Yes, it should be a GFI.
    How old is the fridge?
  4. beeger11
    beeger11 New Member
    Apr 30, 2009
    Its an old fridge. Dont really know how old it is. But it will be ok to do with a GFI?
  5. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Maybe not, but the GFI is required and a good idea.
    Old fridges are power HOGS! You are better off biting the bullet and getting a new one. It will pay for itself in a few years for sure.
  6. jadnashua
    Depending on how old the house is, that recepticle might already be controlled (protected) by a GFCI somewhere else. If so, it is supposed to have a sticker on it, but people often neglect to do that or they come off.
    If it isn't already protected, then you should add one, then use the load connections on it to power the second recepticle...no need to buy two as long as the one you do buy has load connections. The incoming power goes to the line connections.
  7. 3m
    3m New Member
    Mar 3, 2009
    NY
    receptacle circuits in garages dont need gfi if they are not readly accessible or single receptacles that in your case only serve a icebox thats not easily moved to plug something else in according to the 2005 nec code book now if you add a double receptacle and make it so its easy to plug a extension cord in or anything else then it MUST be GFI protected
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    You can check if it is already GFCI protected by running a small incand. lamp from the short outlet slot to a ground. You can use
    http://images.lowes.com/product/converted/032664/032664481000md.jpg
    If the fridge doesn't have a grounded plug you should add one in case there's current leakage to the case of the fridge. You'd need to run the ground wire to the metal fridge housing, under a screw. Be sure to scrape the paint so you get a good electrical connection.
    Otherwise the fridge could be or become a shock hazard.
    If you plug in the new grounded plug and it trips a breaker the fridge is already a shock hazard.
Similar Threads: Single receptacle
Electrical Forum discussion & Blog Change single receptacle to a duplex? Mar 27, 2009
Electrical Forum discussion & Blog How To Wire Single Pole Light Switch with Pilot Light Dec 11, 2014
Electrical Forum discussion & Blog Converting Two Recessed Lights on a Single Switched Leg Jun 16, 2014
Electrical Forum discussion & Blog a single 3-way switch controlling a light fixture on a knob & tube circuit - why? Jun 12, 2014
Electrical Forum discussion & Blog Can I use 2 single pole 30 amp pushmatic breakers as a double pole set up May 28, 2014
