Single lever shower valve leaking...through the metal !!!
Discussion in 'Shower & Bathtub Forum & Blog' started by pktaske, Feb 6, 2011.
  1. pktaske
    pktaske New Member
    Dec 9, 2010
    New Jersey
    Hey guys! Was getting a wet spot by doorway of my small master bath. Thought it was the drain seal on my shower stall but when I looked behind the wall ( I have access) I see the drip is coming from a few (not one!) small pinholes in the cast valve body!!! I put this in about 11 years ago so it's not that old. I have water with high iron but not that acidic or hard. What could make a valve head sweat water like that? Just plain poor construction? Anybody ever seen this before?
    I haven't pulled it out yet as I wanted to push the job off till next week. I tried some epoxy but water pressure seems too strong to hold and I can't keep the pressure off on the valve for more than an hour because we need the water flowing in the rest of the house.
    Thanks . . .
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It could be corrosion or, just a hole caused by casting sand used in the molding...
    It doesn't matter it's replacement time...
  4. jimbo
    jimbo Plumber
    San Diego, CA
    There is a rumor that Billy Mays died because he tried to epoxy a pipe under pressure! Yes...you have a situation not often encountered, and yes...you need to replace as soon as possible.
  5. jadnashua
    Depending on the brand, many have a lifetime warranty, and if you call them and explain what's going on, they'll send you a new one. Better than money out of your pocket!
  6. hj
    Usually that indicates a foreign valve which used a poor grade of brass. Many imported items using the poor brass get "holes" in them.
  7. jadnashua
    A porous casting happens, but most good places weed them out. Happens to cast aluminum wheels, too, sometimes which can be a real pain.
  8. jockygerald
    jockygerald New Member
    Feb 7, 2011
    manager
    Chicago, IL
    one thing we all should be taken care is use of water with maximum efficiency ,can all of you think that is shower is only option for bath?
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    When you wallow in grease, mud, blood, and sewage on a daily basis- yes I think a daily shower is in order. The more water the better.
  10. pktaske
    pktaske New Member
    Dec 9, 2010
    New Jersey
    ok.. I sent pics of the valve (complete with leaking water and hole in the shower wall) to American Standard and as a 'courtesy' they are sending me a new valve even though I don't have my receipt from 11 years ago.
    How nice of them.
  11. Terry
    Aug 17, 2004
    Can you post the model number and the picture here?
    That is good of A/S for supporting you that way.
Similar Threads: Single lever
Shower & Bathtub Forum & Blog Do the springs in a Delta single lever unit have to be replaced if still good? Jan 27, 2013
Shower & Bathtub Forum & Blog Gerber Single Lever Tub / Shower Combo Jan 12, 2012
Shower & Bathtub Forum & Blog Single lever shower faucet won't turn to the left. Jul 23, 2011
Shower & Bathtub Forum & Blog Single Lever Shower Valve Ultra sensitive and difficult to adjust temperature May 16, 2010
Shower & Bathtub Forum & Blog Price Pfister Single lever shower NO COLD! Aug 5, 2007
