Single Handle vs Double Handle Faucets.
Discussion in 'Shower & Bathtub Forum & Blog' started by dw85745, Jun 3, 2012.
  1. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    Any advantages / disadvantages of a single handle faucet shower with a mixing value versus the old double handle (e.g. Price Pfister) style or is it just personal preference ?
  2. jimbo
    jimbo Plumber
    Old two handle showers do not have the pressure balanced, so called anit-scald feature. As such, they are not allowed for remodel or new construction.
    That said, I have an old PP windsor, and am in no rush to update. Toilet is in the shower room, so no one flushes the toilet while I am in the shower!
    Today, I would recommend a Delta 1700 series, which has separate controls for temperature and volume.
  4. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    I have an old PP I was planning on reusing in this small bath remodel. Has worked great for 30+ years.
    Personally prefer the two versus one handle
    Will take a look see at the Dselta 1700 series.
  5. jadnashua
    Remodels in most places require you to bring things up to current code. Now, the number of handles depends on the design features. Often, the least expensive option is a single handle. Those work as pretty much as on/off switches - full volume once turned on, the more you turn it, the hotter it gets, but no volume control. The next step 'up' is a two handle unit that gives volume control and a separate temperature control knob (or handle). The best choice (in my opinion) is a thermostatically controlled valve that also has two knobs or handles. One is a volume control and the second is a temperature control. All current valves that meet code provide anti-scald. The less expensive version(s) used pressure balance; the more expensive version uses thermostatically controlled cartidges (and may also have pressure balance functions internally as well).
    Trying to reuse a 30-year old valve is not a great idea...repair parts are potentially tough now, and will only get worse. They all will leak or start to look nasty eventually. Why start with something that old on a remodel?
  6. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    Any suggestions on manufacturers of:
    1) thermostatically controlled valve that also has two knobs or handles
    2) two handle pressure balance
  7. jadnashua
    All thermostatically controlled valves have two controls, often they are concentric, but that's not always the case. One controls the volume and the second controls the temperature. The thing I like about them is once you find your ideal temp, you never have to change it, only turn it on and off.
    While I'm sure others make them as well, a good option is to get the Delta R10000 rough-in valve that will accept all three types of today's shower control valves. The cartridge that determines the type comes with the trim. The big box stores tend to sell the things as a complete package which limits your choices. A good plumbing supply store will sell the two bits separately (rough-in and trim). I put one of these in at my mother's house, and it works well for her. At home, I've got a Grohe unit. It worked out better for my specific application.
  8. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    Thanks Jim for the feedback.
  9. jimbo
    jimbo Plumber
    The Delta R100000 valve accepts multiple functions: it can be the two-control pressure balanced model 1700 that I referenced. It can also be the thermostatically controlled 17T. And of course, it can be the single control press.bal 1300
  10. hj
    IF you "love" a two handled faucet, there are remote pressure balance units, made for Kohler and Grohe for example, which install in the piping ahead of the faucet to make them code compliant.
Similar Threads: Single Handle
Shower & Bathtub Forum & Blog Single handle shower identification Jan 15, 2017
Shower & Bathtub Forum & Blog Tub single knob handle stuck Oct 14, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Help Identifying Single Handle Shower Cartridge Apr 7, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
