Single handle shower
Discussion in 'Shower & Bathtub Forum & Blog' started by fixitup, Jun 29, 2009.
  1. fixitup
    fixitup New Member
    Jun 28, 2009
    have a family member with single handle shower, as you turn it-- cold and cool water come out spout, but shower will not come on til it becomes warm--is this a water pressure problem?, or normal for single handle shower, --its a new shower----I'm interested in this because I'm going to replace mine with a single handle shower( I was told yesterday that it is the code now)also I may be able to help my family member-----could it be a brand problem???
  2. jadnashua
    Most of the pressure balanced valves don't have volume controls in the traditional sense. As you turn them on, you get nearly full volume. It starts cold and as you turn it further, it gets warmer. It has no association with pressure as to when it will go to the showerhead verses the tub spout (if that's what you're talking about).
    An alternative to pressure balanced valves is a thermostatically controlled one. This will have two knobs or levers; one for volume, and a second to set the temperature.
    Both types normally have a max temperature limit stop. Depending on the brand, it might be set at max when you buy it, or it might be set quite cool. WIth a pressure balanced valve, if you set the max temp during the summer, you might need to change it in the winter when cold is more extreme. That isn't an issue with a thermostatically controlled valve.
Similar Threads: Single handle
Shower & Bathtub Forum & Blog Single handle shower identification Jan 15, 2017
Shower & Bathtub Forum & Blog Tub single knob handle stuck Oct 14, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Help Identifying Single Handle Shower Cartridge Apr 7, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
