simple venting question
Discussion in 'Plumbing Code Questions' started by pivotal, Feb 27, 2014.
  1. pivotal
    pivotal New Member
    Feb 27, 2014
    portland, or
    hello, could anyone tell me if i need to add a curcuit vent to the right of the sink drain in this photo? IMGP2199.jpg
    that's a washer drain on the far right, a separate lav on the far left. the drain in the middle is the one in question. do i need a vent between it and the washer drain that Tees into the vent stack up where i have those double ells?
    i hope i've done both the venting and this posting correctly. it's my first(posting).
    thanks in advance
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would have put another sanitary tee for the sink drain on top of the one for the washer. The way you have it, the washer draining is going to siphon the sink's trap.
  4. pivotal
    pivotal New Member
    Feb 27, 2014
    portland, or
    thanks for the response cacher. i'm a little dense, but i think i follow. so there would be two lateral arms flowing to the stack? being more of a carpenter, i'd love to try and avoid all those holes in the framing.
    btw, what part of wisconsin?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Correct, 2 separate arms. You will need to make sure they are installed low enough for the sink that you plan to use.
    I am from NW WI, but am currently between Milwaukee & Chicago.
  6. Terry
    Aug 17, 2004
    [​IMG]
    It's common for a laundry tray and washer to be plumbed together.
    If the washer is plumber over the sink, it will siphon the trap.
  7. hj
    There is more than one problem with having the sink drain installed where and how you show it. The vent would have to be ON the sink drain before it connects to the horizontal line, to start with.
Similar Threads: simple venting
Plumbing Code Questions Venting using a horizontal drain from kitchen sink OK? Dec 16, 2016
Plumbing Code Questions Double Vanity Venting Jan 16, 2016
Plumbing Code Questions Venting lower level laundry Jul 18, 2014
Plumbing Code Questions Circuit venting question Apr 18, 2013
Plumbing Code Questions Venting Question Nov 30, 2011
