Brewmaestro
Here are the specs:
Hand-driven sandpoint, 1.25" galvanized pipe 27' deep, aquifer at around 21', 3/4 hp jet pump. Put into service early this spring.
The system seemed to work okay, though it had a rather meagre output of around 5.5 GPM (posted about that here: https://terrylove.com/forums/showth...Air-(well-not-me-my-well)&p=298107#post298107). But since I plumbed it into the house's sillcocks and started using it to irrigate the garden, it's begun hesitating. Here's what happens: you turn on the water and get plenty of flow till the pump kicks on, then the output drops to zero. The pump continues to run but sounds different, then after a period of time the flow resumes and would pump all day if I let it. The period of no flow has been increasing--at first it was just a little bloop in the flow; now it stops for a minute or more.
What's likely to be my problem and what can I do about it? Thanks much for any help.
Brewmaestro
Brewmaestro
