eod4647
- Messages
- 18
- Reaction score
- 0
- Points
- 0
Good Morning,
Just a quick question. I have well (submersible pump) that is used for watering horses. No pressure tank or anything, just turn the switch to get water and the pump operates continuously. It's usually on only for a few minutes to top of their water tank. It had a leak in the pipe and I pulled it yesterday. The leak (small hole/split) in the 1" PE pipe was about 81" from the top. Which was actually a good thing because it allwed the water to drain back down to below the frost level.
The question is, is there some sore of valve I can install about that far down that will do the same thing? If there is, where can I get one online?
It gets rather cold here in ND and I'd rather not have the pipe freeze. I don't recall it frezzing previously before the leak appeared, but I don't recall. I'm pretty sure the check valve on the pump works as I used a hose to fill the pipe and find the leak once it was out of the ground and didin't notice any water coming out the pump.
I guess the other option would be some heat tape on the top eight feet or so. Thanks for the advice.
