Simple Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LocalLoser, Jan 22, 2009.
  1. LocalLoser
    LocalLoser New Member
    Jan 22, 2009
    I know this is probably an easy question for some but I'm stumped. I have to replace my metal drain pipes under my sink. I want to replace everything from the pipe that goes into the pipe coming out of the floor all the way up to the strainer. I'm replacing the metal with pvc. My question is what should I use as a sealant between the metal pipe coming out of the floor and the beginning of the pvc pipe that has to go inside the metal pipe? I know there should be a sealant used there to prevent gases from coming up out of the pipe. I'm just not sure if I should use plumbers putty or maybe a type of caulk? Any help would be appreciated.
  2. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Can you post a pic?
    Sounds like a S trap if it's coming out of the floor instead of the wall.
  4. LocalLoser
    Jan 22, 2009
    Sorry I don't have a digital camera but your right. My drain pipe is coming out of the floor. It my kitchen sink drain pipes that I'm replacing.
  5. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    The problem with s-trap is that they can siphon pulling the water out of the trap and breaking the water seal.
    Did you smell sewage gas before?
  6. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    Is the iron pipe threaded ? If so pvc threaded adapters are available .
  7. jastori
    jastori Member
    May 2, 2008
    Illinois
    That connection should not rely on a sealant. Depending on the type of pipe coming out of the floor, you should (hopefully) be able to find the proper connector without too much trouble.
  8. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    S trap aside, if the metal pipe (galvanized¿) is threaded teflon enriched pipe dope or teflon tape on threads will suffice.
  9. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You need to have a trap adaptor on the metal pipe. You can not just slide the plastic inside and "glue" around it.
    If I hear J.B. Weld I swear I'll, I'll......:eek:
  10. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Dude JB weld is awesome stuff. I use it for everything.
  11. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Redwood passes the duct tape helmet to NH Master...
    [​IMG]
  12. LocalLoser
    Jan 22, 2009
    ktsks22a.jpg I'm not sure if you can see this image but it is of an s trap. The bottom section is the part that is extended down into the metal pipe coming up from the basement. There is a connector to attach it but I'm worried about gases from the drain.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    In order to help you we have to know in what manner the s-trap will be connecting to the drain. Either a good description or, a picture is needed.
  14. LocalLoser
    Jan 22, 2009
    Attaching the pvc pipe to the drain is not the problem. The problem is the drain pipe coming up from the basement is metal. It ends at about 3 inches above the bottom of the inside of my kitchen sink cabinet. There is a threaded connector there but the old metal pipe that was there (before it rusted through) was also inserted about 8 inches down into the pipe coming up from the basement. It was connected by a threaded connection (female to male) but when I removed the old metal pipe it looked like they had also used some kind of greasy substance to seal the pipe.
  15. Redwood
    Dec 15, 2007
    Service Plumber
    So put in a new nipple and put a slip joint adapter on that.
Similar Threads: Simple Question
Plumbing Forum, Professional & DIY Advice Copper Vertical Vent Pipe Question (Hopefully Simple, But Very Important) Dec 4, 2014
Plumbing Forum, Professional & DIY Advice Simple VENTING Question - Basement Tub / Wet Bar Rough-In Oct 4, 2011
Plumbing Forum, Professional & DIY Advice A Simple question.....Why is there more than one code for plumbing! Aug 11, 2010
Plumbing Forum, Professional & DIY Advice Simple P trap question Jan 6, 2009
Plumbing Forum, Professional & DIY Advice 3" ABS - Simplest question ever. Apr 26, 2007
