Hello,
I've got a leaky bathtub single-handle faucet, which is a should be a pretty easy DIY repair, so I had the faucet apart this evening, but ran into a little hitch with the disassembly.
Basically, I shut off the water supply, and removed the cover plate, handle, and chrome surround, as well as the plastic collar. At this point, I'd expect to see some type of threaded ring-nut, or metal clip to hold the "mixing valve" in place.
Alas, I can't find any such retaining device. Rather it looks like the remaining piece is one single molded plastic cover, with threading on the outside to accept the surround and 8 trapezoidal indents in the middle. I'm guessing that the mixing valve sits behind this little piece.
I was wondering if someone could take a look at the following pictures and make a suggestion. Is there perhaps a specific tool that goes into these 8 indents and allows me to turn this whole piece counter-clockwise to unscrew? The plastic is far too soft to allow me to attempt to unscrew with large pliers, so there's something else going on.
You can see pictures of the removed parts here:
http://www.christianedstrom.com/faucet/parts1.jpg
and there are two different views of the cover here:
Any advice much appreciated. The building is a 1920s apartment, but the faucet appears to be fairly new. Less than 15 years old, at least. No discernible brand or markings anywhere.
Best regards,
- Christian
Best regards,
- Christian
