Sillcock Types, Conventional vs. Quarter Turn
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sagittaire, Nov 30, 2008.
  1. sagittaire
    sagittaire Mechanical Engineer (Retired)
    Oct 10, 2008
    Anacortes
    I'm adding two sillcocks, and am trying to decide between conventional globe-type anti-siphon frost-free sillcocks and quarter-turn anti-siphon frost-free sillcocks.
    Questions:
    1) What are the advantages and disadvantages of each type?
    2) Does the quarter-turn type adequately modulate the water flow? (Such as for trickle flow watering of plants)
    3) Are the Legend Valve Company products T-552 and T-550 good quality frost-free sillcocks?
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Woodford sillcocks...
    just get yourself a couple of woodford sillcocks..
    we have tried them all over the years and most have
    caused us nothing but greif..with call backs, ect.....
    the Woodford common frost free sillcock has never , ever
    failed us in 20 years....
    if you put those in and remember to take off the hose in the winter time,
    they wont give you troubles for a long time
    [​IMG]
    [​IMG]
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Woodford is good and reliable, nothing wrong with them, but I happen to like the Legend 1/4 turn hose bibs as they are well made...the only draw back that some may not like is that in some instances I have to ream the existing hole about 1/4" or so...
    [​IMG]
    [​IMG]
  5. Juneappal
    Juneappal New Member
    Apr 25, 2009
    Repair leaking legend
    I have exactly the model of legend sillcock shown. I like how it feels and operates, except that mine is now leaking. This winter, we had a pretty good freeze here in seattle - several consecutive days with temperatures between 10 and 25 degrees. That did it in.
    The chrome cover on the top unscrews to reveal plastic threaded pressure/vacuum relief valve of some sort. There is a black rubber gasket inside that plastic housing. During the hard freeze, that gasket somehow squeezed up through the crossbars on the plastic housing. I couldn't get it back in, so I took it all the way out.
    I don't know if that is the cause of the leak, but the leak also happened this winter. Now the spigot has a minimum flowrate of about 5 gallons/day. Without that gasket, the spigot can't hold pressure, so we have to leave an open hose on the spigot to prevent a constant slow drop of water down the side of the house.
    Anyone have any success repairing one of these sillcocks? I can't get at the back end, unfortunately, so replacement would be a pain in the ...sheetrock.
  6. Terry
    Aug 17, 2004
    If the faucet will not shut off, you can buy a new faucet and rob the interior parts.
    If the faucet shuts off, and it only leaks out of the vacuum breaker, you can replace those parts.
    If the faucet shuts off, but leaks from the pipe behind, which would be if the hose was left on and ice split the copper tubing, then you have to replace the faucet.
  7. Juneappal
    Apr 25, 2009
    Probably "A"
    I think I am on "A." It never shuts off completely.
    I buy a new unit, how much of the guts will I be able to replace? Can I get that black rubber washer back in, or replace that white plastic housing? I guess there is one way to find out.....
  8. Terry
    Aug 17, 2004
    As long as you have the right length, it will all replace.
  9. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I will say I am not impressed with the quarter turn bib's we've been using. Someone's always going out to do service on them.
    [​IMG]
  10. Cass
    Cass Plumber
    Nov 12, 2005
    As of yet I haven't had any problems with the Legend 1/4 turn valves...
    Yours sounds like it may be installed, pitched the wrong way severely...thats all I can think of...unless you left the hose on and it froze...it only takes 1 freeze even B 4 you removed it...
  11. Juneappal
    Apr 25, 2009
    Bingo
    I had a flow splitting assembly - two hoses on one spigot kind of thing. I probably left the sillcock open and the two split valves closed - that would do, I think.
  12. Cass
    Cass Plumber
    Nov 12, 2005
    That would do it...replacing the guts may not work depending on what was affected when it froze....
  13. Roger the Carpenter
    Roger the Carpenter New Member
    Sep 12, 2009
    Rhode Island
    A little *Bumpage* here: I'm interested in hearing the answers to questions #1 and #2. A divergence OT is great when it goes that way, but I've just installed a 1/4-turn anti-siphon jig on my sister-in-law's house, and am curious to know how I did! Maybe I missed something, but I'm not clear on the resolve of this post...
  14. bugmugs
    bugmugs New Member
    Sep 16, 2009
    Charlottesville, Virginia
    Where to get parts?
    In an answer to one of these posts, someone mentioned replacing the parts in the vacuum breaker. Try hard as I can, I can't find anyone online or around town who offers frost-free sillcock parts for sale. Anyone have any suggestions? (I have a Legend model T-550.)
  15. alexlloyd
    alexlloyd New Member
    Aug 22, 2011
    Manitoba
    Same here
    I have the same legend sillcock and it leaks too. I bought it at *********. Is there a repair kit or am I buying a whole new valve. It the option is a whole new valve, i will avoid a legend as it should last more than two years. As for Seattle and freezing, two winters at minus forty that may have contributed to the leak but I have never removed the hose, drained or adjusted it and it never froze.
  16. jadnashua
    There are a few hose bibs that can survive freezing, but other than those, you WILL break something if you leave a hose on and it freezes. The only chance you might have is if the hose can drain easily. ANy trapped water WILL freeze at -40, and it will damage the valve unless it is designed for it...most aren't designed to have a hose left on.
  17. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I wish the 1/4 turn hose bibs were available when I built my house. I also wish they could standardize on the length so that I could change them out without having to resolder the pipes. I've had to change out one of the originals already and will eventually change them all.
    As for regulating flow, I do it at the other end of the hose, not at the hose bib.
  18. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Why would you solder it right on anyways?
    I just solder a FIP adapter to a chunk of pipe, tighten it onto the hose bib, and then use a coupling to join up to the rest of the pipe in the house...
Similar Threads: Sillcock Types
Plumbing Forum, Professional & DIY Advice Freeze Proof Sillcock outdoor faucet Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Advantages of offset sillcock? Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Outdoor Sillcock question Jun 9, 2016
Plumbing Forum, Professional & DIY Advice Connectors for polypipe to sillcock? May 26, 2016
Plumbing Forum, Professional & DIY Advice Frost-Free Sillcock freeze damage May 16, 2016
