Sill plate location ... in or out?
Discussion in 'Remodel Forum & Blog' started by Lakee911, Aug 11, 2009.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Do I set my sill plate on my foundation out the thickness of the sheathing so that it's flush with the outside of the sheathing or do I set it back so that it's flush with the framing?
    Any advantage in putting down a sill sealer if I'm not insulating or heating the building?
    Thanks,
    Jason
  2. hj
    sill plate
    Usually you put it even with the framing and then use a "J" metal or similar to set the siding onto.
  4. Lakee911
    Aug 23, 2005
    Columbus, OH
    Flush with the framing it is. Thx
  5. jch
    jch Member
    Jan 3, 2006
    Victoria, British Columbia, Canada
    Yes, it will act as a moisture barrier between the porous concrete foundation and your wooden sill plate. Building code (here, at least) specifies that untreated wood can never be in direct contact with masonry.
    ../j
  6. Lakee911
    Aug 23, 2005
    Columbus, OH
    Thanks for info. My sill plate will be a pressure treated 2x6. Upon that I'll build a 2x4 wall. I think that I'll put down anyhow.
    This is in regard to the garage that I'm building. Check out progress here.
Similar Threads: Sill plate
Remodel Forum & Blog Methods for sealing sill plate to foundation? May 18, 2013
Remodel Forum & Blog XPS basement insulation and foundation sill plate Jul 30, 2012
Remodel Forum & Blog Bath Window Sill Sep 8, 2012
Remodel Forum & Blog Waterproof windowsills Oct 27, 2007
Remodel Forum & Blog Mass 8th Edition Base Code & Sole Plate Jun 17, 2014
