Silicone or Putty??
Discussion in 'Shower & Bathtub Forum & Blog' started by Waltman, Jan 27, 2009.
  1. Waltman
    Waltman New Member
    Sep 19, 2007
    South Jersey
    When mounting the drain to a whirlpool tub, is it best to use Silicone Sealant(GE II Kitchen and Bath) or straight up plumber's putty?
    Or does it not much matter at all??
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    If the tub is acrylic, its best to use silicone
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Holy calculus, batman! Please don't start the silicone/putty debate again!
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    either one will work
    either one will work...
    putty is more forgiveing
    if you use the silicone,
    you will probably never --ever get it apart again
    I have had to burn off basket strainers from a SS kitchen sink with a blow torch before,
    becasue someone used silicone
    let the dabate rage
  6. Cass
    Cass Plumber
    Nov 12, 2005
    I have a customer that has to replace the whole sink because his G/D is leaking and whoever installed it years back used some kind of epoxy or something...that it can't be removed from the sink and the style of mounting flange that it is is not available any more....and he called to tell me that the installer also used the same stuff to mount the sink so he may have to change the counter top also now....gota love the DIYers...
  7. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    That's pretty funny when you think about it.
  8. Waltman
    Waltman New Member
    Sep 19, 2007
    South Jersey
    Thanks all. Mark, I like the idea of forgiveness, putty it is...
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I use this no matter what the sink or, tub is made of.
    [​IMG]
  10. Waltman
    Waltman New Member
    Sep 19, 2007
    South Jersey
    What am I doing wrong??
    Using the STA-Put Ultra (stainless) to hook up a FG/Acrylic tub & drain.
    Can't seem to get the drain spud to seal at the tub flange. Been through this 3 times now with varying amounts of STA-Put. Admittedly, I applied too much putty on my first attempt :rolleyes: On the first try, putty got between the washer and the bottom of the tub flange...(too much putty I assumed).
    The remaining 2 times, used considerably less (single bead, about 3/16" in diameter, at the edge of the spud). Should have worked, but didn't. :mad:
    Am I tightening too much, or not enough? (Yes, the washer is on the BOTTOM of the flange...) I'm clamping it down fairly tight, I think...at least until putty stops oozing out...using a basket wrench...
    Is there a set sequence for installation that I should be following?
    Even if I get it right, now having trouble trusting the seal
  11. Waltman
    Waltman New Member
    Sep 19, 2007
    South Jersey
    Nevermind!
    Found the problem:
    Where the drain bowl meets the horiz drain pipe is a FACTORY joint - LEAKS, grrrrr...
    It's going back and I'm selecting a different brand.
    There's 4 hours of my life I'll never get back...
  12. hj
    drain
    The putty ONLY stops the water in the tub from leaking away, with some drains you would not even need it. The bottom gasket is what prevents leaks, so if you have a leak that is where the problem is, not the putty.
Similar Threads: Silicone Putty
Shower & Bathtub Forum & Blog Putty or Silicone? Apr 16, 2009
Shower & Bathtub Forum & Blog Please share if your trim pieces have silicone, Polyseamseal, or nothing? Yesterday at 2:04 PM
Shower & Bathtub Forum & Blog More silicone??? Dec 4, 2016
Shower & Bathtub Forum & Blog Color matched 100% silicone for Mapei Ultra Color Plus May 26, 2014
Shower & Bathtub Forum & Blog Shower surround - horrible mess with silicone caulk May 8, 2013
