Silicone or plumbers putty?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by joeriley2005, Dec 10, 2011.
  1. joeriley2005
    joeriley2005 New Member
    Nov 13, 2011
    Bothell, WA
    I'm installing my new drain kit to my new shower pan and the instructions say to put silicone between the drain and the pan. I've always used plumbers putty but I should I use silicone in this case since the instructions call it out?
    What do the plumbers prefer?
    thanks
  2. Terry
    Aug 17, 2004
    I've been using Silicone.
    Putty can dry out over time, and then the drain will be loose.
  4. hj
    For that application, I use silicone, but be sure NOT to get it on the strainer's threads, because it could keep it from tightening properly. Plumber's putty often begins to leak and usually it is difficult to get to the nut to loosen it and reset the drain.
  5. Belmondo
    Belmondo Member
    Dec 15, 2011
    New Jersey
    So where do you guys still use putty? I've used it for seating stainless drop in sinks, as per directions, but I think I saw a plumber on a home improvement show use silicone there too. What about the basket on that sink?
  6. hj
    atound the sink, I use "tub and tile sealant", NOT putty or silicone. The basket strainers, depending on the brand, I use plumber's putty, although some do NOT require anything other than the rubber seal.
Similar Threads: Silicone plumbers
Plumbing Forum, Professional & DIY Advice Acrylic Tubs - Silicone vs Plumbers Putty Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Silicone Vs Plumbers Putty May 6, 2016
Plumbing Forum, Professional & DIY Advice Danco Plumbers Waterproof Grease vs Danco Plumbers Silicone Grease Oct 11, 2007
Plumbing Forum, Professional & DIY Advice PVC cement - compatible w/ silicone sealant? Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Replacing Old Kitchen Faucet - Putty or Silicone Jun 14, 2016
